06-10-2022, 08:29 AM | #1 |
Having FUN in the SUN...
BEST EXPANSION TANK
Hey guys, i see ALOT of options for underhood expansion tanks in size, location, material, etc... I was curious which you all think is the most effective?
at 2 gallons... and in the fender.... this one seems like a great option? https://synergymotorsports.com/produ...ion-water-tank https://dedicatedmotorsports.com/ZL1-2GAL/ This is going to be added to my phase.2 build of cam + ported blower + lower pulley + 103tb + big Gulp Also, has anyone considered re-purposing the windshield washer fluid tank for this?
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi Last edited by SOCAL.M6.ZLE; 06-10-2022 at 08:53 AM. |
06-10-2022, 08:44 AM | #2 | |
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
06-10-2022, 09:17 AM | #3 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
I suggest a trunk tank. Higher capacity and typically easier to fill/drain if you want to ice the car down. Keeping what you want to be cool water away from the engine is also good.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
06-10-2022, 06:18 PM | #4 | |
Makes sense... I's like to stick with a smaller one under the hood (less weight) and I dont plan to crank the boost that high... anyone have the fender mount version with install photos?
06-10-2022, 06:28 PM | #5 |
Petro-sexual
Cordes has about a 2-gallon, underhood tank that goes below the hood latch that seems to be a good option.
06-10-2022, 06:43 PM | #6 | |
I saw that one also... but it looks like you need to cut a large whole to access the lid... which i didnt like... :(
06-10-2022, 09:33 PM | #7 | |
I have the dedicated motorsports fender tank. Nice tank, fits right behind the fender, connected to my IC. Just need to drill one of the holes, i can't remember which one, but install is a piece of cake.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-10-2022, 09:50 PM | #8 |
Drives: HBM ZLE Join Date: Aug 2017
This is the adm tank
06-10-2022, 10:46 PM | #9 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
What is the capacity of the adm tank? From what I've read it's not much and doesn't help much at all..
What is your take and do you have data? |
06-10-2022, 11:39 PM | #10 |
No data right now, its the larger tank but I got it mostly to deal with any air in the system. Not so much extra capacity because its not even a gallon. Does what i need it to do, Just throwing another option out there
06-11-2022, 12:14 AM | #11 |
It’s really to make filling easier. Holds maybe half a quart at most.
06-11-2022, 09:51 AM | #12 | |
Do you have any install photos?
06-11-2022, 10:18 AM | #13 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Though I'm stock but still running at WOT around a road course for 20 minutes takes a toll on any vehicle. This is useful in keeping the air bubbles out of the lines. |
06-11-2022, 10:56 AM | #14 |
Looking CLEAN! Cant wait to hear your beast!!! When can you make it out to Escondido Cars and Coffee?
