Vararam
Old 06-08-2012, 06:19 PM   #1
cid067
cid067's Avatar
Drives: Black 1SS/RS LS3 M6 "The Toy"
Cam installation
About to Buy a cam just curious on the difficulty of installing the cam as I have never done this before. I prefer working on my car myself but not sure about doing the cam install myself, would hate to not get it right. So my question is is this a difficult install or can a novice do a cam install? I know we all have to start somewhere and the easy mods are no problem just need some advice on difficulty.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
cid067 is offline   Reply With Quote
Old 06-08-2012, 06:32 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
There is a pretty good diy here on it....do a search.
Still, if you have to ask how hard it is, you should at least get someone to help you who knows what he's doing because if you mess something up it could be an expensive mistake.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 06-08-2012, 06:34 PM   #3
thesnoopster
thesnoopster's Avatar
Drives: '17 Fifty SS - '18 Traverse Redline
Im sure someone will hook you up with some good valuable information
2017 Camaro SS -"FIFTY"
Mods: "93 Octane"
thesnoopster is offline   Reply With Quote
Old 06-08-2012, 08:26 PM   #4
Kiowa88
Out Front!
Kiowa88's Avatar
Drives: OH-58D (R)
I did my cam swap off Robertways DIY in the DIY section. Other than the cam swap, the most extensive install were headers. As long as you feel comfortable after reading his write up I'd say give it a shot. If you have patience and the right tools, it shouldn't be too bad. Definitely get a second hand. It helps when you get frustrated and prevents the verbal abuse to your car.
Good luck putting the oil pump back on and getting the pick-up tube aligned right. That part had me wanting to put a hole in the wall.
B Troop, 3-17CAV - Out Front
Kiowa88 is offline   Reply With Quote
Old 06-08-2012, 11:08 PM   #5
cid067
cid067's Avatar
Thanks for the input still havent decided but leaning on doing myself once I order.
Old 06-08-2012, 11:11 PM   #6
Ivan @ Southwest Speed
Drives: '15 Z06, '01 NBM SS, '97 SS
Easy day...
Great writeup:
http://www.camaro5.com/forums/showthread.php?t=125123
Ivan @ Southwest Speed is offline   Reply With Quote
Old 06-09-2012, 11:14 AM   #7
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
Personally I wouldnt touch it. Its quite a bit of work.
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 06-09-2012, 11:26 AM   #8
Bo White
Bo White's Avatar
Do it. Take your time and have plenty of containers and baggies to label. Give yourself a full weekend so to not be rushed and in case you run into something.
Totalled:
Old 06-09-2012, 11:48 AM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
+1 on taking pictures just before disassembling something and bagging the bolts and parts.
Take your time and get the right torque specs on the items like cam sprocket bolts, timing cover bolts, oil pump bolts etc etc. I'd say the hardest part to remove and install is the damn crank pulley ( please please buy the longer bolt to reinstall the crank pulley from rpmspeed it's only a couple of bucks but worth it, if not you'll strip the beginning threads on your crank). Other than that you'll be happy you did it yourself and proud to say your ride is built not bought! Lol you can also post up here for questions and I'll subscribe to lend a hand online at least lol. Good luck bud
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 06-09-2012, 12:12 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
+1
Here are your torque specs:
http://www.ls1howto.com/index.php?category=1
but I believe they are listed in the DIY.
Also, I used tape to label the connections, parts, etc. I also wrote the torque specs on the bags that held the parts so it sped things up when I went to put things back together.
Old 06-09-2012, 12:14 PM   #11
cid067
cid067's Avatar
Thanks for all the input. After reviewing the write up I think I will do it myself. I will probably get the cam this coming week and either do this next weekend if I dont go to the track or the following. Thanks again for all the input.
Old 06-09-2012, 12:55 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Awesome! Go into it thinking your going to have some fun and get to know your car better. Like a hot date that you know is going to give it up and allow you to stab her with your cam! It just takes some time to undress her that's all lol.
Ps upgrade while your there, c5r timing chain, melling oil pump, arp cam bolts,arp crank bolt and arp head bolts not head studs. If you get these you can reuse them many times and torquing them down is easier than doing the Gm torque to yield bolts that are good for one time only.
Old 06-09-2012, 01:12 PM   #13
cid067
cid067's Avatar
Now that sounds like good times.
Old 06-09-2012, 01:17 PM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i found a local guy that does all the ls motors and blower work around my area , its his side job, so i will endup leaving my car there for a weekend to a week depends on how much he as to work at his first job but for 200 bucks , i wouldnt chance it im sure someone in ur area could hook u up and or help u do it, its easy to mess up on the pushrods and such.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
