TireRack
Old 09-23-2019, 09:14 AM   #1
camaross94
camaross94's Avatar
Drives: 2012 Camaro 2SS/RS
Help! Front splitter is pulling down on front bumper
So my splitter is pulling down on the bumper, and the spot is right in the middle under the front grill. I was wondering, for whoever has had a front splitter/front lip setup, if this is something that has happened? Any way to easily fix it? Picture for reference of my setup
2012 Camaro 2SS/RS- 445 HP/ 428 TQ
Hurst short throw shifter, SLP exhaust, Texas Speed Longtube headers, high flow cats, & x pipe, BMR lowering springs, toe rods, trailing arms, MRR M716 wheels
camaross94 is offline   Reply With Quote
Old 09-23-2019, 10:00 AM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Looks like the connecting rods are mounted straight to the bumper. Not sure what you can do now so that you can not see the holes in the bummer. You should’ve connected them to braces behind the lower grill. Only thing I can think of is make a bracket coming off of your bumper braces and connect them to it.
Camaro2ss2010 is offline   Reply With Quote
Old 09-23-2019, 02:52 PM   #3
fly2hip8
Drives: 2013 Camaro 2SS
Yea, those braces need to be mounted to something solid. They will do no good but ruin your bumper now
fly2hip8 is offline   Reply With Quote
Old 09-23-2019, 05:36 PM   #4
camaross94
camaross94's Avatar
Where exactly behind the grill? Is there a pic for reference , so I can change it up. It pulls down on it a bit, not terrible but slightly annoying having to pop it back into place.
Old 09-23-2019, 05:47 PM   #5
Dizzy82
Dizzy82's Avatar
Best option is to drill through the bumper and mount it directly to the reinforcement bar. Ideally you should have gone through the lower grill mounting it to the reinforcement bar.
Old 02-16-2022, 03:12 PM   #6
Ssauce2
Ssauce2's Avatar
Drives: 2010 Camaro 2ss
Does anybody have pictures of this ? Should front bumper come off to attach to reinforcement bar ? Because I made the mistake too
Ssauce2 is offline   Reply With Quote
Old 02-16-2022, 05:46 PM   #7
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
It should be mounted to the steel bar behind the plastic bumper.
Car Nation Videos is offline   Reply With Quote
Old 02-16-2022, 08:14 PM   #8
BatmaroBeauty
BOOST OR BUST
BatmaroBeauty's Avatar
Drives: 2010 Camaro 1LT
This happened to my old bumper and permanently warped the plastic so definitely try to fix it sooner than later. Luckily, a solution I found was a product from Aerosport Concepts called an support rod crash rail hardware kit. It basically does exactly what everyone in here is describing and connects your crash support bar to your existing splitter support rods through the bumper holes you’ve already created. Here’s some links and photos better describing install:
https://www.instagram.com/p/BxymNRMH...dium=copy_link
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . .
BatmaroBeauty is offline   Reply With Quote
Old 02-17-2022, 07:07 AM   #9
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Now that looks solid!!!!
joekono is offline   Reply With Quote
