04-02-2019, 11:42 AM | #1 |
Drives: 2014 Camaro 2SS Join Date: Oct 2017
GPI SS1 CAM SUPPORTING MODS
So I'm thinking about going with a SS1 cam from GPI. It's a daily driven street car so I don't want to go with a big cam. Obviously it's getting the AFM delete and I'm adding headers.
But the question I have is if you could pick between say a 3200 Circle D stall or Eaton Trutrac diff/3.91 gear swap. Which would you do with the SS1 cam if that's all your budget would allow? I'm having a hard time thinking which would be a better bang for your buck... |
04-02-2019, 11:52 AM | #2 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
if your car were manual, the answer is easy: 3.91 and trutrac
i would ask Rhino79 or give GPI a call and ask them. They'd give you the best answer
Bone Stock |
04-02-2019, 12:00 PM | #3 |
Drives: 2014 Camaro SS L99 Join Date: Dec 2016
I have this cam with a 3600 triple disc and stock rear end. Still breaks the wheels and it’s a whole lot of fun to drive
Sent from my iPhone using Tapatalk |
04-02-2019, 01:56 PM | #4 | |
Drives: 2011 Camaro SS Join Date: Sep 2017
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
04-02-2019, 05:23 PM | #5 |
Drives: 2012 SS Red w/ black rally stripes Join Date: Jan 2015
Don't let the "SS1" name fool you, this is not necessarily a small cam. My camaro is a daily driver. I started with headers and a tune and got the mod bug for more power but still wanted to daily drive the car anywhere. GPI has a great reputation so I contacted them for recommendations on a cam. I wanted to daily drive it and did not want to spend the money for a converter. Aaron recommended the SS1 to meet my goals at that time. I purchased everything form them. I have HP tuners and Ryan remote tuned it for me. With stock gears and no converter, it sounded great, made lots of power and it had great street manners. After a time, I felt the need for more power. I decided I wanted to supercharge it. Again, I contacted the guys at GPI. Aaron told me we could make the SS1 work with the Magnuson Heartbeat. I purchased the supercharger from them and again Ryan remote tuned it. The car is a beast and it's daily driven on fair weather days. I agree with sixtyfordkiller, contact GPI, they won't steer you wrong. Keep in mind you'll need to be willing to perform the maintenance necessary for big cams, changing valve springs etc.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
04-02-2019, 07:14 PM | #6 |
Drives: Camaro Join Date: Oct 2018
Bigger than 3200 stall and 3.91s later
04-03-2019, 06:40 AM | #7 |
GPI Sales Consultant
Definitely a stall before gears if you gotta choose one. A lot of guys also make the mistake of not going as big as they wish they would have with the stall - I would let the guys at GPI give you some direction on what would work best for your now, and in the future if you do go 3.91s (which you really should!). The other thing you can consider while doing budget upgrades is the ported rod-mod intake from GPI. Worth 10-15rwhp in a cammed car, that's a good pickup for a very reasonable price. If you're already getting your install and tuning done anyways it's essentially no extra work.
Got a question about a GPI product? Feel free to shoot me a message! |
04-03-2019, 07:15 AM | #8 |
Thanks for all the replies guys. So I gave GPI a call yesterday about adding a stall or gears to their SS1 cam and they said a stall isn't necessary with this cam and gears would make a slight improvement, but really the bigger cams benefit from it more.
I scheduled an appointment to drop off the car early June to get the cam swap done. The Camaro is climbing high in mileage currently at 80,xxx so I figured I'd get some maintenance stuff done while the car is apart and also address a few weak links: - new L99 oil pump - Katech C5R timing chain - new LS3/LS7 rocker arms with trunnion upgrade - new lifters (not sure which ones to go with yet) What do you guys think should I add anything else? I'm not sure who I talked to exactly on the phone when I called. I'm going to call again and ask them what lifters they recommend (they have a few options with the cam package on their site), how they feel about the 160 degree thermostat (I read good and bad on this forum), and I'll bring up the stall and gearing question again. |
04-03-2019, 07:26 AM | #9 |
You live in the south, 160* for sure. I'd buy a ported rod-mod before I ever spent money on a C5R timing set. LS3/LS7 lifters should be plenty fine for an SS1, relatively cost effective. They aren't wrong, an SS2, if you're willing to do a stall, would be much more awesome. Depends on your usage. Good thing about GPI is they won't steer you wrong, and you won't beat their service!
04-03-2019, 08:21 AM | #10 | |
04-03-2019, 10:07 AM | #11 | |
for your lifters, either: chevrolet performance part# 12499225 or if you have the $$$ go with johnsons ST2126LSR or ST2116LSR
Bone Stock |
04-03-2019, 08:25 PM | #12 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
I'm running a GPI SS1 VVT cam and agree with the others, go with the converter first but you need 3800-4000, 3200 is too low for where this cam makes power. The RPM difference won't change street feel but it will make a huge difference when you romp on it. This cam builds power north of 3800 RPM which was really evident for me when I ran the stock converter for a year then upgraded to a Circle D 3800. At the track with the stock converter flashed around 1900 RPM, launching like it did when stock, but as it climbed above 3600 RPM it was like the afterburner kicked in. With the 3800 stall it flashes at the start of the power band (not before) so now I'm in the afterburner from the hit....which then becomes a traction problem :-o.
Over the winter I picked up drag radials to help with traction, and also have a 3.91 w/TruTrac diff ready to install next week. I'm really expecting solid improvement across the board, esp. 60' time.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
04-03-2019, 10:16 PM | #13 | |
I rarely get above 200* anymore and am usually between 172 -192* coolant temp. Before the 160* stat, I would hit 212 at lights in the summer. It made a huge difference in my idle and cruising temps, which means less KR. With my 160* stat, I never go full retard!
04-04-2019, 06:54 PM | #14 | |||
