03-21-2022, 11:11 PM | #1 |
Drives: 2018 Red ZL1 Join Date: Mar 2018
19” ZL1 1LE wheel fit ZL1?
Hi Guys
Don’t know why but my search function not working. Hope this easy question… I have 2018 ZL1. Looking for second set of racing wheels/tires. I’m seeing a couple sets of 19” supercar 3R’s tires available around me. If I can find set of 1LE rims…do they fit with no issues? I know there are different shocks between the two, but don’t know if they would fit w/o rubbing. Would like to know for sure before dropping 2-3k… Thanks Jim
Mods: RotoFab Big Gulp, 2" Kooks, Metco 9.1" pulley, Green belt, 103 NW TB, Tune, WeapX Boost Chiller, ADM Coolant reservoir, Jokerz Full Tilt SC Port, Elite E2X Can, Corsa Sport Catback, LED markers, 1LE Tail lights, HO reverse LED's, Red SC Lid, Forgestar 17x11/MickeyT Street R's for Drags
03-22-2022, 12:04 AM | #2 | |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
03-22-2022, 12:22 AM | #3 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Its my understanding that to make 19" OEM ZL1-1LE wheels fit a regular ZL1, the front strut needs notched to make them fit. A few videos out there on YouTube on how to do. Want to say the more recent one is the lonestar Hawaiian.
03-22-2022, 10:06 AM | #4 |
Dyno Show Queen LOL
OH crap I better notch..
03-22-2022, 10:30 AM | #5 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
Shock clearance I believe is only an issue if you change the camber using the knuckle.
03-22-2022, 10:36 AM | #6 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Here is a fitment article for different sized tires/rims for different applications and it explains about the steering knuckle issue: https://support.apexraceparts.com/hc...-Fitment-Guide Go about 3/4 of the way down and read the section on steering knuckle clearance and it shows what needs to be trimmed. |
03-22-2022, 11:05 AM | #7 | |
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
03-22-2022, 11:34 AM | #8 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
I put OEM Z/28 wheels onto a '17 ZL1 I had. I used 5mm spacers in front to avoid trimming/notching the strut. I went about 3 days without the spacer...right up until the point where I pulled into my driveway with the wheel fully turned and scratched the shit out of the inside of my wheel on the front (because of not notching and no spacer). The ZLE wheels are the same size and offset as the OEM Z/28 wheels for the front, so you definitely should be notching or putting a spacer.
Current: 2018 ZLE (M6/hyper blue)
Former: 2014 Z/28 (red hot); 2017 ZL1 (auto/white); 2015 Z/28 (black); 2016 2SS (auto/hyper blue); 2012 2SS (45th anniversary/auto); 1994 Firehawk (auto/dark green); 2005 GTO (M6/blue on blue); 1999 Camaro SS (M6/pewter); 1994 Z/28 (auto/blue); 1991 Firebird (auto/red); 1988 IROC (auto/copper metallic); 1983 Camaro (auto/blue); 1981 Firebird (auto/maroon/350 Olds swap)....the list goes on... |
03-22-2022, 11:37 AM | #9 |
03-22-2022, 11:51 AM | #10 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
I haven’t had any issues with my wheels. No spacers or grinding was required. I think they will be ok as long as you retain the stock alignment.
03-22-2022, 12:02 PM | #11 |
If you get under the car with the wheel turned and take a look at the notch area on the strut....you can barely get a piece of paper in there between the strut and the wheel. If you see how close it is, it might make you nervous lol.
03-22-2022, 01:22 PM | #12 | |
Other than that, run a 5mm spacer (or not) and you'll be fine if you're staying at street camber. If you go to the aggressive track camber, then you'll probably start see issues with the wheel hitting the steering knuckle. Because if you read the article......the track setup's state the you COULD have issues and need a spacer up front for those aggressive track cambers. Last edited by Vigilante375; 04-03-2022 at 10:25 AM. |
03-22-2022, 04:04 PM | #13 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
No trimming notch for the 19". It is the 18"s you will have to do that. Additionally, you have to move the wiring harness on the Driver's side rear. It takes about 10 minutes to move it.
03-22-2022, 08:20 PM | #14 |
run a small 3mm-5mm spacer and they fit with track alignment...no notching required. I used 19" ZL1 1LE wheels/tires for many laps at VIR in my '17 ZL1.
