03-21-2020, 01:05 PM | #1 |
Drives: V6 2LT Camaro Overkilled Join Date: Jun 2018
Wiring diagram for the LED tail lights
Hi, is there someone who has a wiring diagram of the LED tail lights, which are used on the RS,SS and ZL1 models? On the plug i see 6 pins, I found out that there are two grounds, one positive for the reverse light, one for the brake/turn light and one for the actual tail light, but have no idea where does the 6th go.
03-21-2020, 01:23 PM | #2 |
Here’s a thread discussing your topic. It may give you the answer you desire.
https://www.camaro6.com/forums/showthread.php?t=549679
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
03-22-2020, 07:06 AM | #3 | |
The guy is having the same problem as I am, but the thread ends there. |
03-23-2020, 05:11 PM | #4 |
Drives: 2016 Camaro RS Join Date: May 2016
What problem are you having?
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
03-24-2020, 09:29 AM | #5 |
Well I wanted to have tail lights with yellow/orange turn signals, so i purchased EU version tail lights. But i didn't know that the EU camaro use the revese light as a turn signal and so the wiring is different for the US and EU models and now I get hyper flashing when i use the turn signals, even though my stock tail lights are LED.
https://drive.google.com/file/d/17C8...4fb83e5f2jsN8i On the attached picture you can see one of the pins is missing on the new tail lights |
04-06-2020, 12:27 PM | #6 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
These are for a 2019, but they should be the same
04-06-2020, 01:08 PM | #7 |
04-06-2020, 06:11 PM | #8 |
Geoff
Best guess is that you'll get a message that the lamp is out.
08-12-2020, 05:17 AM | #9 | |
Drives: Camaro 2SS 1LE 2019 Join Date: Aug 2020
Peter |
08-16-2020, 05:34 PM | #10 |
08-17-2020, 05:56 AM | #11 |
08-17-2020, 11:46 AM | #12 | |
Geoff
Hope this helps
09-26-2020, 08:06 AM | #13 |
12-19-2020, 05:00 AM | #14 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Very useful, especially for European models that miss the side markers and the DRLs.
Do you or someone else have a similar diagram, but for the headlights? I am trying to figure out which wire in the headlight to tap into in order to fit aftermarket fog DRLs. Thanks Last edited by MakCamaro; 12-20-2020 at 04:48 AM. |
