03-16-2024, 12:14 AM | #1 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
Dash logic
It's me again😂🍺
2013 M6 ZL1 I've had a dash logic since I bought my car 2 years ago. I just finally got around to installing the flex fuel sensor tonight. The car has not been tuned yet. I don't see the pid for displaying alcohol (ethanol) content in the dash logic menu. Is this only available after it's tuned? I'm taking it to the tuner next week and I wanted the feature available to help them out and avoid any delays |
03-16-2024, 06:46 AM | #2 |
They have to turn the ethanol parameter on in the ecu first
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-16-2024, 12:16 PM | #3 |
03-18-2024, 08:49 AM | #4 |
Did you try playing around with the settings on the dash logic? It should technically read how much ethanol is in the gas. Even if it's minute amount.
03-18-2024, 11:21 PM | #5 |
I did. I connected it to my computer and put it in config mode. The PID for alcohol content was not even present. I thought it should be there since it's just reading the signals the car is putting out. Without ECM having been tuned for E I would think it would just display zero.
05-08-2024, 02:33 AM | #6 |
Update. I contacted the dashlogic manufacturer and they informed me that v1.15 does not include the alcohol pid. They sent me v2.3 which has been working great.
05-09-2024, 10:38 PM | #7 |
Drives: 13' 1LE Join Date: Apr 2012
Dash logic is good stuff
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
