02-18-2022, 10:19 AM | #1 |
Recaro seats
Has anyone have problems with the Recaro seats
In regards to the bolster’s stitching ? |
02-18-2022, 10:44 AM | #2 |
None. I like them.
'20 ZL1 1LE A10,
02-18-2022, 11:08 AM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Nope. Stitching is good on mine. 2018 with nearly 30k miles.
02-18-2022, 11:57 AM | #4 |
Petro-sexual
My stitching, near the outer seat belt mount, started separating. That was with less than 2K-miles. I took it in a little more than a year from new-purchase, and it was replaced under warranty. GM had to pre-approve the warranty, but there was nothing they could say that was anything but a manufacturing issue.
02-18-2022, 12:23 PM | #5 |
Radz, they replaced the complete seat or just recovered
The seat with new leather?? |
02-18-2022, 10:09 PM | #6 |
No issues with mine either.
02-18-2022, 10:36 PM | #7 |
Petro-sexual
They replaced the exact cover that had the failing stitching. Everything else was original. They had to remove it from the car, FYI.
02-18-2022, 10:44 PM | #8 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
No issues here, although that’s to be expected since I just got the car
That said, I’ve been quite impressed with the seats so far! In particular I wasn’t looking forward to loosing a full leather surface, but alcantara looks very nice (to me), and of course there is the benefit of being less slippery. And on top of that, they hug you really well, even for a guy of my small size. Anyway sorry, back to the topic at hand Geoff |
02-19-2022, 06:23 AM | #9 |
Radz, so they removed seat from car, and replaced the bolster section only? Did they repaired it in house, or sent it out? How long did the repair
Take? Thx |
02-19-2022, 07:02 AM | #10 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
My driver’s seat bolster is starting to show some wear on the side closest to the door from getting in and out of the car. Whenever I drive my Camaro or Corvette, I usually move my wallet from a back pocket to a side pocket so it doesn’t catch on the bolster when I get in the car.
02-19-2022, 09:28 AM | #11 |
Thank you Al Oppenheiser!
02-19-2022, 09:46 AM | #12 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
It helps if you use the feature that slides the seat all the way back when you enter and exit the vehicle. It helps you avoid sliding across the bolster and wearing it down.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
02-19-2022, 05:46 PM | #13 |
Well, the seat is all the way back,I’m tall, so, unless I can remove
The useless rear seat ( ha ha) I just have to squeeze in, went to Stealership for warranty on this, and they say they have to remove The seat from car, and The top half of leather seat has to be removed And new top half installed over the existing foam! That’s a hard job! I don’t know why they just install a complete New seat! Hopefully they’ll send it out! |
02-19-2022, 06:03 PM | #14 |
Not hard for a pro. In and out in < 2 hrs tops.
