Old 03-24-2022, 03:10 PM   #1
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
BMR Drag Race Suspension
I am about to replace my Carlyle kit minus the small brake kit with the BMR drag race kit. I was wondering if anyone has some suggestions on the Strage Coilover settings to start out, car is mostly street and about 5-6 drag races throughout the summer. I know some people are top secret when it comes to suspension load and settings, but any insight would help! I'm coming from QA1 coil shock on a medium setting, thanks!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-24-2022, 08:51 PM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
If you dont mind me asking, why are you switching from the Carlyle to the BMR conversion? I have been looking at both.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 03-25-2022, 11:02 AM   #3
NoDakZ/28
NoDakZ/28's Avatar
I can't get the carlyle kit to lower as much as id like, also the carlyle lca's are designed to be used with factory struts and I blew out a qa1 coil strut because of that. I got a nice deal on the bmr kit so I pulled the trigger, I just wanted more adjustment on rebound and height with the strange coilovers. Nothing wrong with the carlyle kit(which by the way bmr bought them out) but you are limited to ride height with stock strut/lowering springs is all.
2014 1LE - Sold
Old 03-27-2022, 08:59 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Gotcha and thanks for that info. How low were you trying to go? Im at 1" lowering spring now which is fine for me.
Old 03-27-2022, 09:19 AM   #5
NoDakZ/28
NoDakZ/28's Avatar
You bet, I’d like to be right around that 1” lower than stock. The qa1 and 1” lowering spring my ride height was around stock with the Carlyle lca’s.
2014 1LE - Sold
Old 05-09-2022, 09:18 PM   #6
Heads-up
Drives: 2010 2SS
I just installed the BMR drag pack with strange coilovers. They suggested "Compression 6 clicks rebound 4 clicks from softest setting" as a starting point with a drag radial on the track.
Heads-up is offline   Reply With Quote
Old 05-10-2022, 09:40 AM   #7
NoDakZ/28
NoDakZ/28's Avatar
Thanks, that's is where I started. Find out in a few week and dial it in at the track.
2014 1LE - Sold
