10-30-2023, 08:20 PM | #1 |
Drives: 2013 camaro 2ss 1le Join Date: May 2020
Sooooo... This isnt good right?
changed my oil over the weekend and on a whim decided to buy a filter cutter and pop one open for the first time, and im reasonably certain what i found should be cause for concern, but i figured id ask anyway.
for the picture of the oil, the dark normal oil drained from the filter before i cut it (and all of the oil from the sump looked the same), the lighter sparkly oil is what came out of the pleats from me folding it up and squeezing the oil out trying to make them less shiny. all of the large shiny bits around the periphery can be ignored, its either garbage that was in the drain pan already or the texture of the pan itself. for the picture of the flecks, i just took a picture of the largest ones i could find. for scale, the large splinters are about 1.5-2mm long each and the larger of the smaller flecks scattered about are all around +/- .5mm or so (not the dust but the distinct flakes). those are the only 2 distinctly large chunks, the rest are small/medium flakes or dust. also i just took a video of the entirety of the pleating since i figured it would be more convenient than like 45 pictures. https://youtu.be/yTXB3lwkAC4
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners |
11-04-2023, 07:43 PM | #2 |
anyone? bueller?
11-04-2023, 08:47 PM | #3 |
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
I've cut a couple of filters and was shell shocked at what I saw. That being said, it's been years and all is still well! I don't see anything alarming but I'm by no means a veteran filter cutter.
11-05-2023, 12:23 AM | #4 |
Give speed a chance
Personally I've never cut open a filter (but I probably should!). Are any of the particles/pieces ferrous? Maybe check with a magnet. I'm a BIG fan of Blackstone analysis, you may want to send in a sample.
11-05-2023, 01:37 AM | #5 |
"Yellow metal" color is more worrying.
11-07-2023, 06:53 PM | #6 | ||
im assuming you mean the color of the glitter in the oil?
11-07-2023, 07:24 PM | #7 | |
11-07-2023, 07:29 PM | #8 | |
11-07-2023, 07:32 PM | #9 | |
11-07-2023, 10:25 PM | #10 |
I did this and it came back unremarkable. Currently at 79k and hasn't missed a beat. Things like this come from manufacturing, mostly and if all works well, end up...in the filter. The chunks you see would likely never make it into the Blackstone sample container.
11-07-2023, 11:36 PM | #11 |
