02-08-2010, 08:20 AM | #1 |
Drives: 2010 Black/Black 2SS Join Date: Jan 2010
Different rim sizes = speedometer reading wrong?
With the 2SS offering both 20" and 21" wheels, it seems to me that the speedometer will be inaccurate on one of the packages. What does GM use as a baseline calibration for the speedometer, the 20" or 21"?
Also, does the V6 18" use the same calibration? It seems to me that with all the different sizes, someone's speedometer is going to be off. |
02-08-2010, 08:22 AM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
rim size has nothing to do with the speedometer, they all have the same overall tire height
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
02-08-2010, 08:29 AM | #3 |
02-08-2010, 10:48 AM | #4 |
Drives: '20 Corvette Stingray Join Date: Jul 2009
02-08-2010, 11:04 AM | #5 |
Drives: 2010 Camaro 1SS 2007 HD FLSTC Join Date: Aug 2009
02-08-2010, 11:33 AM | #6 |
I FARTED
Drives: 2010 2SS/RS Join Date: Nov 2009
Speedometer goes off revolutions of overall diameter of rear wheels/tires. Go to a bigger rim, you put a shorter sidewall tire on to get the same diameter as before. However, if Chevy wanted to create different diameters between the 18's, 20's and 21's with their tire sizes they could have b/c a speedo can be calibrated easily to correct tire sizes.
