09-22-2020, 06:09 PM | #1 |
SICC
Drives: 2014 2SS1LE Summit White Camaro Join Date: May 2014
will 325 30 19 Eagle F1 Supercar 3 fit square?
Will 325 30 19 Eagle F1 Supercar 3 fit square?
Hello I was seeing if anyone knows or has run 325 eagle f1 supercar square on their z28 with stock suspension. I am at maxed out with camber. Thank you. |
09-22-2020, 07:11 PM | #2 |
It partly depends on your wheel offset. And you state you are maxed out on camber, what is your camber #? What tire are you currently running?
I just did 325/30-19 Goodyear 3R square on my '14 1LE with the Z's DSSV struts. I run 20mm offset front wheels and used a 5mm spacer, effectively making it a 15mm offset. But I also have Vorshlag camber plates at full in. As long as you have about .250" clearance between the tire and the strut you will be good. You may need a small spacer. Take a look at your current clearance and make the call from that. If you are already near .250" clearance then you'll have to run a spacer.
09-22-2020, 07:18 PM | #3 | |
SICC
Sent from my SM-G892A using Tapatalk |
09-22-2020, 07:35 PM | #4 |
Drives: '14 1LE Join Date: Nov 2013
It may not help, but I run 325 square MPS4S on Z/28 wheels, but with coilovers (not OEM DSSV).
09-22-2020, 07:37 PM | #5 |
I am currently at -2.3*/-1.6*, but I have the Detroit Speed Kit 1 springs and ARBs on the DSSVs. Your Z/28 wheels have an 11mm offset, so that helps. You are currently running 305/30 up front?
I do not have any rubbing anywhere.
09-22-2020, 07:42 PM | #6 | |
SICC
09-22-2020, 07:56 PM | #7 |
My first move would be to see what clearance you have now. The Tire rack specs a section width of 13" for the 325/30-19 F1 Supercar 3 and 12.3" for the Rival 305/30-19. That is .350" (on paper) change in sidewall width on one side that will eat into any clearance you currently have.
09-22-2020, 07:58 PM | #8 |
I installed longer wheel studs long ago in anticipation of being able to fine tune with spacers of varying thickness. I can go to 12mm with no problems. But I believe with the OE studs, 5mm is the max spacer.
09-22-2020, 08:38 PM | #9 |
Build Date - Dec 08, 2014
Drives: 2015 Z/28, #1007, Black A/C Stereo Join Date: Oct 2015
A 5mm spacer will still allow 8 full turns of the lug nuts on stock studs. Would recommend switching to some Detroit Speed open ended lug nuts to make certain you have achieved enough coverage on the threads.
09-28-2020, 09:26 PM | #10 | |
Drives: 2015 Camaro Z/28 Join Date: Jan 2011
how it would be affected with your maxed out camber. |
09-29-2020, 03:13 PM | #11 |
SICC
Thank you
09-29-2020, 03:37 PM | #12 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
You can certainly run 325-30-19 square on all four corners with Michelin Piiot Sport Cup 2 tires. They corner like a scalded dog on my Z.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
