Old 09-22-2020, 06:09 PM   #1
SummitWhite1LE
SICC
SummitWhite1LE's Avatar
Drives: 2014 2SS1LE Summit White Camaro
will 325 30 19 Eagle F1 Supercar 3 fit square?
Will 325 30 19 Eagle F1 Supercar 3 fit square?
Hello I was seeing if anyone knows or has run 325 eagle f1 supercar square on their z28 with stock suspension. I am at maxed out with camber.
Thank you.
SummitWhite1LE is offline   Reply With Quote
Old 09-22-2020, 07:11 PM   #2
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
It partly depends on your wheel offset. And you state you are maxed out on camber, what is your camber #? What tire are you currently running?
I just did 325/30-19 Goodyear 3R square on my '14 1LE with the Z's DSSV struts. I run 20mm offset front wheels and used a 5mm spacer, effectively making it a 15mm offset.
But I also have Vorshlag camber plates at full in. As long as you have about .250" clearance between the tire and the strut you will be good. You may need a small spacer.
Take a look at your current clearance and make the call from that. If you are already near .250" clearance then you'll have to run a spacer.
cdb95z28 is offline   Reply With Quote
Old 09-22-2020, 07:18 PM   #3
SummitWhite1LE
SICC
I also have vorshlag camber plates I am at -3.3 front 1.9 rear. I am also a 14 1le with stock z28 suspension and wheels. Did you have any rub when you are turning lock to lock?
Sent from my SM-G892A using Tapatalk
Old 09-22-2020, 07:35 PM   #4
AG1LE
AG1LE's Avatar
Drives: '14 1LE
It may not help, but I run 325 square MPS4S on Z/28 wheels, but with coilovers (not OEM DSSV).
AG1LE is offline   Reply With Quote
Old 09-22-2020, 07:37 PM   #5
cdb95z28
cdb95z28's Avatar
I am currently at -2.3*/-1.6*, but I have the Detroit Speed Kit 1 springs and ARBs on the DSSVs. Your Z/28 wheels have an 11mm offset, so that helps. You are currently running 305/30 up front?
I do not have any rubbing anywhere.
Old 09-22-2020, 07:42 PM   #6
SummitWhite1LE
SICC
Yes I have been on 305 30 19 rival for the last two seasons for autocross I was thinking about running these for next season
Old 09-22-2020, 07:56 PM   #7
cdb95z28
cdb95z28's Avatar
My first move would be to see what clearance you have now. The Tire rack specs a section width of 13" for the 325/30-19 F1 Supercar 3 and 12.3" for the Rival 305/30-19. That is .350" (on paper) change in sidewall width on one side that will eat into any clearance you currently have.
Old 09-22-2020, 07:58 PM   #8
cdb95z28
cdb95z28's Avatar
I installed longer wheel studs long ago in anticipation of being able to fine tune with spacers of varying thickness. I can go to 12mm with no problems. But I believe with the OE studs, 5mm is the max spacer.
Old 09-22-2020, 08:38 PM   #9
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
A 5mm spacer will still allow 8 full turns of the lug nuts on stock studs. Would recommend switching to some Detroit Speed open ended lug nuts to make certain you have achieved enough coverage on the threads.
AustexaSS is offline   Reply With Quote
Old 09-28-2020, 09:26 PM   #10
RaycinSS
RaycinSS's Avatar
Drives: 2015 Camaro Z/28
Thank you.
These are the exact tires with stock wheels that were on my car when I purchased it. I had zero issues with rubbing running the stock alignment settings. I don't know if/
how it would be affected with your maxed out camber.
RaycinSS is offline   Reply With Quote
Old 09-29-2020, 03:13 PM   #11
SummitWhite1LE
SICC
Thank you
Old 09-29-2020, 03:37 PM   #12
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
You can certainly run 325-30-19 square on all four corners with Michelin Piiot Sport Cup 2 tires. They corner like a scalded dog on my Z.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
