Old 11-17-2010, 04:17 PM   #1
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
DIY remove door handle
hello, had a request by a member to do a post on removing the door handle. so here it is.
1. tape as in the pic, put some tape also on the end of a flat blade screw driver, carefully pry up the cap that cover the key mechanism.
2. remove plug from inside door, use a #20 torx bit and begin to turn counter clockwise until it stops, while turning the screw, wiggle the key lock and lift it out. you might need to pull on the door handle just a bit for the lock to come out.
once the lock is out, screw the torx screw in until it stops, if you look in the hole you can see the 2 teeth move that hold the lock. this is important.
now with the lock out of the way, you will have to pull the handle out, like if you are going to open the door and toward the rear at the same time, on the next pick you can see the little lever arm that the handle is pulling on. you will here a snap as it clear and the little lever pops back in. remove door handle.
ok now to get the handle back it, i took some thin wire and pulled the little lever forward and pushed the handle in and once it was in i pulled the wire out.
now you can screw the torx bit counter clock wise again and see the teeth going back, you might have to wiggle the door handle a bit the get the lock to seat, once it seats, screw the torx bit in until it stops. Put the cover back on, again you might need to wiggle the door handle a bit.
lupe
overhaulengines is offline   Reply With Quote
Old 11-17-2010, 06:13 PM   #2
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
not sure why anyone would need this besides shaved handles, but you can never have too many DIY's
Thanks for taking the time to help people out!
Chewy is offline   Reply With Quote
Old 11-17-2010, 09:09 PM   #3
overhaulengines
Well, not sure why he wanted to take them off, but the reason I know how is when I painted the car we pulled the door handles off. Maybe he has a messed up lock or maybe pin stripping the car. But it is fun for me to share wat I have learned.
Lupe
Old 11-17-2010, 09:25 PM   #4
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
thanks for sharing
Lupe
Thanks for sharing this.You never know when you might need to do this.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 11-18-2010, 12:22 AM   #5
VcrusaderV
VcrusaderV's Avatar
Drives: 2018 ZL-1
Thanks. Very good instructions.
2010 2SS Camaro (sold)
2010 ZL 427 Camaro (sold)
2012 ZL-1 Camaro (sold)
2018 ZL-1 Camaro
VcrusaderV is offline   Reply With Quote
Old 11-23-2010, 12:37 AM   #6
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: Sold c7, in the market!
+1
khabboub is offline   Reply With Quote
Old 02-20-2011, 05:13 PM   #7
shy68
shy68's Avatar
Drives: 2010 2lt RS,Have 68,69 camaro
I had to remove mine.Thanks
shy68 is offline   Reply With Quote
Old 02-20-2011, 08:18 PM   #8
overhaulengines
Glad this helped. Did I miss anything or would u add anything to make it easier?
Old 02-21-2011, 10:03 PM   #9
shy68
shy68's Avatar
I removed it just fine,with the instructions you listed.Never seen one like this before.
Old 08-19-2011, 02:46 PM   #10
EpileptikRobot
EpileptikRobot's Avatar
Drives: 2011 Camaro 1LS
Im thinking about removing mine to paint them. Hope i can follow directions lol.
EpileptikRobot is offline   Reply With Quote
Old 07-20-2012, 06:30 AM   #11
coolxxx
Royal Scorpion
Drives: Camaro R/S (pimped)
hello man,
can you please explain how could you get the cable out, if you want to install a small led strip from the inside part of the handle?
coolxxx is offline   Reply With Quote
Old 07-21-2012, 10:05 AM   #12
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
Will the passenger's side cover fit over the driver's side lock? I am thinking about deleting the handle lock.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 07-24-2012, 10:30 AM   #13
SS 2NV
SS 2NV's Avatar
Drives: 2010 Camaro SS/RS
Yes the Passenger side cover works on the Drivers Side. I've had it done for a couple years now and love it.
2010 Camaro 2SS/RS Summit White| Black Leather Interior | JBA LTH 1 7/8" 3" High Flow Cats | 3" Magnaflow Comp Cat-Back | CAI Intake | SCT Tuner with Jannetty Tune | Pfadt 1.25" Lowering Springs | Pfadt Front and Rear Sway Bars | Heritage Grill | Revolution Styling Chin Spoiler | Fesler Moss Fiberglass Side Rockers & Rear Diffuser | MPD1 Rear Spoiler | Tinted Windows | Camaro Chrome Under the Hood | AAC LED Fog Lights | PSI Laser Etched Mirrors |
SS 2NV is offline   Reply With Quote
Old 07-24-2012, 11:12 AM   #14
cntryman77
cntryman77's Avatar
Drives: 2010 Camaro LS
there have also been guys who have bought Cruze door handles for a different look...they are a direct replacement...see this thread
http://www.camaro5.com/forums/showthread.php?t=228685
cntryman77 is offline   Reply With Quote
DIY: PDIM + USB Port installation jtzako Camaro DIY & HOW-TO instructions & discussions 159 12-30-2017 04:02 PM
DIY : Install Lowering Springs on 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 42 03-29-2017 01:31 PM
DIY: How to Change the Door Speakers RandyB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 04-26-2014 10:53 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 09:31 PM
