06-07-2014, 01:55 PM | #1 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
Oil cloud
Just a quick question. Today I decided to play around in the car. I took off insecond and hit the rev limiter on accident and noticed a cloud of smoke that smelled like oil come from the exhaust. I went a little farther and pulled over, I could smell oil from the engine area but it quickly went away. Not seeing any leaks of any sort, but what I did notice was a little oil from around my oil breather. So I am curious if I should be worried, or if the oil pressure got high and forced the oil out from the breather. I hope I explained that well enough.
06-07-2014, 03:32 PM | #2 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Take the oil breather cap off and put your hand over the opening. If you feel positive pressure....bad news. If not, you're probably ok. If you do feel pressure with each lope of the motor, you probably popped a ringland.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
06-07-2014, 03:48 PM | #3 |
what do you mean positive pressure?
06-07-2014, 03:54 PM | #4 |
Cover the oil fill port with your hand while the car is idling. You should not feel any pressure on your hand. If anything you should feel a slight vacuum. If its bad you can even see little puffs of smoke with each lope of the motor.
Thats what mine did when i blew the #5 piston ringlands. Big cloud of oil smoke while romping on it. This was on my OE motor at 715whp and 11 psi.
06-07-2014, 03:57 PM | #5 |
took the breather off and covered the port. definitely a good vacuum. Like I said I am just wondering if oil did come out of the breather and drop down on the headers which caused the puff.
06-07-2014, 03:58 PM | #6 |
im not seeing any puffs off smoke or smelling it
06-07-2014, 04:04 PM | #7 |
Thats good. YOu could have forced a little oil past the rear main seal and onto the exhaust causing the smoke also.
06-07-2014, 04:08 PM | #8 |
So I should be good to go? Had me nervous!
06-07-2014, 04:09 PM | #9 |
what catch can are you running and does your oil breather have a check valve in it.
06-07-2014, 04:12 PM | #10 |
Rx can and breather
06-07-2014, 04:12 PM | #11 |
Which I know the Rx breather doesnt really have a check valve from what I have read. Well doesnt let pressure out.
06-07-2014, 04:18 PM | #12 |
When i had the RX monster can and breather i had to remove the check valve from the breather. Too much crankcase pressure under high boost. What boost/HP are you at?
I was at 750whp on my old D1SC setup and had a large puddle of oil under the car on the dyno tune runs....pushing past the rear seal. Pulled out the valve and it was fine. With my current setup i scrapped the POS RX can and run -10 lines off each valve cover to a vented catch can.
06-07-2014, 04:23 PM | #13 |
im well below that hp.. i am at 511.
06-07-2014, 04:24 PM | #14 |
i believe it is at 8lbs
