Old 10-22-2020, 04:02 PM   #1
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
LMS NEW CUSTOM LT4 STAGE 3 CAMSHAFT
Livernois is very well known for our custom lines of camshafts that we use in our day to day building procedures but we are always looking for ways to improve and taylor our products to certain customers needs/wants. This is where we introduce our newly designed and marketed LT4 stage 3 camshaft we used on a customers build on a zl1 pushing just under 900RWHP SBE!Ive attached a video link so you can hear it rip on the dyno as well as here the nice idle this camshaft produces as well as a link to the number on our website for anyone interested in specs, this build was one of my personal favorites!
https://www.livernoismotorsports.com/product/LPP801141
Livernois Motorsports is offline   Reply With Quote
Old 10-22-2020, 04:39 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Converter needed for a10s like many other stage 3s?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 10-26-2020, 08:20 PM   #3
JFWJR179
JFWJR179's Avatar
Drives: 2022 Camaro ZL1 Convertible A10
Sounds great.
My questions:
1. Converter needed for A10 ?
2. What is the Fuel Lobe spec ?
JFWJR179 is offline   Reply With Quote
Old 10-27-2020, 12:30 AM   #4
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
VVT locked?
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-27-2020, 06:44 AM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
My Cammotion stage 3 has very similar specs and I run without a converter. If I was daily driving it I would probably add the converter tho as the car does buck rolling up to stops.
Markoz28 is offline   Reply With Quote
Old 10-27-2020, 06:50 AM   #6
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I ran one of Livernois cam in my first Forged Build. It shouldn't require a converter since its still a PD blower that doesn't need to ramp up and boosts instantly. The A10 has a lower 1st gear then the A8 so just don't think its needed.
Old 10-27-2020, 10:17 AM   #7
This application actually does not require an aftermarket TC!
Old 10-27-2020, 10:18 AM   #8
No issues with bucking on our side of things, this customer drives it all the time i would not consider it daily but very very often
Old 10-27-2020, 10:58 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Correct based on that aspect. However Larger cams(depending on the amount of positive overlap) often require more idle rpm and they tend push on the brakes with a stock converter. A higher stall is normally looser so it requires more rpm to get moving and will soak up that increased idle rpm. This will keep the engine from trying to push through the brakes. Not saying the cam being discussed will need a converter, just mentioning it because others are asking likely in reference to this.
2016 NFG 1SS A8
Options-2SS Leather/NPP
