06-21-2019, 05:46 AM | #1 |
Drives: 2018 ZL1 Convertible Join Date: Sep 2017
Tony Mamo or Soler?
Has anyone done the comparison between the two throttle bodies to see which is a better bang for the buck?
I'm looking to combine that with a Rotofab CAI.... If so, please share. |
06-21-2019, 06:15 AM | #2 |
The LT5 TB with adapter is more cost effective and flows more air than either one of those. Plus, it gives you room to grow, should you decide to put a smaller pulley on the blower.
06-21-2019, 07:52 AM | #3 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
06-21-2019, 07:59 AM | #4 |
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500 Join Date: Jan 2019
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
06-21-2019, 08:05 AM | #5 |
06-21-2019, 08:09 AM | #6 |
Drives: Camaro ZL1 Join Date: Jan 2018
Can you even fit the LT5 TB to the OEM supercharger? I thought you needed to at least port the snout?
06-21-2019, 08:11 AM | #7 |
You have to use an adapter ring. There are a few companies making them now. Also need the ring because the bolt pattern is different on the LT5 TB. Porting the snout is highly recommended but not required.
06-21-2019, 08:46 AM | #8 |
Drives: 2018 Camaro ZL1, 2017 Z06/Z07 Join Date: Jan 2019
I have removed the Mamo TB and replaced it with a Soler on my Z06. The Mamo is an improvement over OE, the Soler is a significant improvement over the Mamo, in my experience. When I purchased my ZL1, the first thing I did do the car was install a Soler TB and Roto Fab CAI. Skip the Mamo and go straight for the Soler. Follow the relearn procedure and never look back.
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1 |
06-21-2019, 09:16 AM | #9 | |
Thanks brother.. |
06-21-2019, 10:28 AM | #10 | |
Drives: 2015 Corvette Stingray Join Date: May 2019
All we'll ask is that you look carefully at the number of features, surface finish, performance plots, geometry scans. Many comparisons done by Corvette 7 owners (LT1/LT4 Engines) and posted at corvetteforums.com. |
06-21-2019, 10:31 AM | #11 |
06-21-2019, 10:34 AM | #12 |
You bet! I posted some questions on the other Camaro6 ZL1 thread that's active (ZL1 Owners, This Super Easy and Very Effective Mod Is For You Too"). When you have a second, can you please advise? Thanks Mike...
06-21-2019, 10:36 AM | #13 |
Drives: 17 C7 GS WGG Join Date: May 2015
Tony Mamo or Soler?
Katech PTB and RotoFab w/standard filter.
Sent from my iPhone using Tapatalk |
06-21-2019, 10:46 AM | #14 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
There’s an option for both. Soler will perform their modifications to a TB that’s already been ported by Mamo.
2018 ZL1 1LE - Red Hot, Nav, PDR
