Old 10-22-2023, 10:37 PM   #1
Gas
Gas's Avatar
Drives: 2018 NFG SS 1LE
turbo SS 1LE
last night i was hanging out with my buddy who just recently finished up his k swapped s2000 with a single turbo on it and it really has me wanting to turbo something.
has anyone had any luck with a single turbo setup on these cars? really dont want twins as i feel it would be more of a PITA.
Gas is offline   Reply With Quote
Old 10-23-2023, 10:02 AM   #2
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Anything can be made to work. Single vs twins really comes down to preference. Are you capable of fabricating anything? What are your goals for the car?
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 10-23-2023, 10:21 AM   #3
Katech_Mike
Drives: 2015 Camaro ZL1
As far as bolt on kits go I believe all that you will find are twins.
We have done some business with Huron Speed in the past and had good results.
https://www.huronspeed.com/products/...turbo-kit-race
If you can fabricate than an appropriately sized single will also work well.
Katech_Mike is offline   Reply With Quote
Old 10-23-2023, 11:09 AM   #4
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Twins are the way to go in this case, it actually makes things simpler as far as exhaust routing. Otherwise you have to put one big turbo somewhere and run all 8 exhaust ports into it. That is not simple and it's far from ideal.
If you want a turbo just buy a T4 Camaro. It's FAR lighter and has 50/50 weight distribution. SS with heads and cam can make the same power as a LT4 pretty easily.
Of course if you want huge power a turbo 8 will do it. IMO it's a massive waste of money unless you're really into drag racing.
DaveC113 is offline   Reply With Quote
Old 10-23-2023, 06:23 PM   #5
Gas
Gas's Avatar
Just a fun street car with occasional trips to Mexico for some racing
Old 10-23-2023, 07:02 PM   #6
jlaudio11
jlaudio11's Avatar
Not sure I would suggest turbo then. Bolt on a blower with some port injection, ethanol blend fuel and a boost a pump. Laynlo15 on here has this setup making 700 wheel hp. Simple, easy and I’m sure a blast to drive. I love my turbo setup but I had a higher goal than just street fun.
'20 Camaro LT1
Old 10-30-2023, 08:20 AM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
The Hellion Twin Turbo system is the way to go we have done a few, once Properly installed and calibrated they will run for ever.
V8 Always do better with twins.
Plumbing a V8 to a single turbo with the space constraints of a 6th gen street car is a nightmare and the engine suffers from imbalance.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-06-2024, 05:55 AM   #8
Choda
Drives: Turbo 6.2
I have a single turbo 2016 ss. Check out my threads for pics. It’s a lot of custom work to make it fit.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
