05-01-2023, 02:12 PM | #1 | |
Driver for Hire
How-To: Blackwing Brake Cooling Ducts
Did a quick video on the Blackwing Ducts. All of the part numbers are in the video description as well.
23385146 - Front Left Mini Dust Shield 23385147 - Front Right Mini Dust Shield 85536980 - Front Right BW Brake Cooler 85536981 - Front Left BW Brake Cooler 84946132 - Rear Right BW Brake Cooler 84946131 - Rear Left BW Brake Cooler 84946133 - Rear Thread Insert for Screws 85004630 - Rear Trailing Arm (FE4/FEA) 85523690 - Rear Cooling Kit 11548166 - Screws x6
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel Last edited by FollowMyLine; 03-04-2024 at 06:56 AM. |
05-04-2023, 06:37 AM | #2 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
could you post the part numbers ive been struggling to even find them online for sale?
05-04-2023, 08:18 AM | #3 |
Instagram: Sangstah
Here you go:
85536980 Front Right Brake Duct 85536981 Front Left Brake Duct 84946132 Rear Right Brake Duct 84946131 Rear Left Brake Duct
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-04-2023, 08:19 AM | #4 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
85536980 85536981 The reason you are struggling is that they HAVE BEEN on national back order for quite some time. If you order some from your local GM dealer be sure to provide him with the VIN number of a Cadillac Black Wing because GM fills those order FIRST before they fill orders for NON BLACK WING owners. Just go to a dealership ad for a black wing and use that VIN. It took me about 6 weeks to get mine but after I provided a VIN they filled that order within two weeks. GOOD VIDEO FollowMyLine!!! We need to tell the boys and girls NOT to overtighten those three bolts that hold these on because you can break the heads off them pretty easily I found out (LOL). I DO NOT have magnetic ride but there was a wheel speed sensor wire that was touching up against the bigger black wing brake duct so I protected it with some split plastic conduit so that it wouldnt chaffe.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 05-04-2023 at 08:31 AM. |
05-04-2023, 09:36 AM | #5 |
Driver for Hire
Here are the mini dust shields for the SS cars;
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
05-04-2023, 10:03 AM | #6 | |
Drives: Chevy Camaro Join Date: Jan 2022
Also I can't find the brake ducts on rock auto im guessing it has to be from gm huh. These are ok to leave on for daily use I'm hoping too. Not sure how much lower they hang
'22 2SS 1LE manual in Red Hot with Red seat belts, alloy pedals, PPF, catch can, and suede kneepads.
05-04-2023, 12:40 PM | #7 | |
Driver for Hire
Attached is a photo of the Blackwing duct on the left and SS track kit on the right, for reference.
Luan Zeqollari
05-07-2023, 04:17 AM | #8 | |
Thanks! So if I have a 1le already I don't need the dust shields? Seems like a pretty cheap and effective upgrade im definitely going to try to pick a pair up
05-07-2023, 07:37 AM | #9 |
Driver for Hire
Only the ZL1 and ZL1 1LE come with the mini dust shields. The SS and SS 1LE have the full rotor shields and need the mini dust shields.
Luan Zeqollari
05-07-2023, 11:45 AM | #10 | |
I think the small (or track) shields are installed by default on ZL1 1LEs, although this last bit I am not 100% sure about as I haven't seen it on a ZL1 1LE and online sources are contradictory. Part numbers are as follows: "Full": 22802367 (left), 22802366 (right) "Half": 23336595 (left), 23336594 (right) "Small": 23385146 (left), 23385147 (right)
05-09-2023, 12:00 PM | #11 | |
Driver for Hire
Luan Zeqollari
05-10-2023, 04:22 AM | #12 | |
05-10-2023, 07:40 AM | #13 |
Honestly, I don't know. However, everyone should already have the small shields (they come in the trunk even with the standard SS), so it's easy to have a working setup while figuring out whether the bigger SS 1LE shield fits or not.
05-11-2023, 09:18 AM | #14 | |
Driver for Hire
The SS hasn't come with the track brake kit in a very long time. I believe that was a 16-17 only, and my 2018 did not include them, and my 2022 didn't either.
Luan Zeqollari
