Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 12-09-2009, 09:49 AM   #1
dpirkey
Drives: 27,50,52 Chevy,51 M38 Jeep,64 Scout
Red face 1967 6cyl. to V-8 Conversion
Some of my mechanic and body friends say that to convert a 6 to an 8, I would need to replace all the front suspension and if I did that, due to the frame being not as strong, I would also have to beef up the frame.I am assuming that I would need new control arms, coils, etc. Is the frame heavy enough?? I have found a 67 at the right price, but if it is going to cost alot to convert, I may be better to keep looking for an original V-8 car. Those of you that have done this, can you walk me through the major points and where do I get the parts and about how much money to complete the conversion of the suspension?? What is your recommendation?
dpirkey is offline   Reply With Quote
Old 12-09-2009, 10:55 AM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
All you would do is MAYBE change the front springs to fix the suspension.
The engine mounts and all the brackets would change, the radiator/shroud may be too small, the crossmember could be on the list depending on what you are building. That is about all the big stuff you need to worry about.
-Mark.
Stingr69 is offline   Reply With Quote
Old 12-09-2009, 12:41 PM   #3
dpirkey
Is the frame itself the same on a 6cyl. as on an original V-8 car, as far as it's weight, thickness, etc.. I know some bracing is required to keep the extra torque from twisting the fame and breaking the windshield. But, is the frame identical as a V-8 frame??
Old 12-09-2009, 02:39 PM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
The sub frame is identical. There isn't anything else major to worry about. The semi-unit body construction is the same with a 6 cylinder or a big block. There was a rear axle traction bar mount on the big engine '67 cars but it isn't that big of a deal for a conversion.
-Mark.
Old 12-09-2009, 06:42 PM   #5
Mr Twisty
Mr Twisty's Avatar
EZ swap... Listen to Stingr
-- Benjamin Franklin
Old 01-01-2010, 11:40 AM   #6
SSRich
SSRich's Avatar
Drives: 1967 camaroSS
u might have to change the coil springs but idk,
my 67 had orginal springs but the ppl had it before i did had torched a couple rings off of it and the car was low so i bought some stock springs and put back under it and it raised it about 3-4 inches.
SSRich is offline   Reply With Quote
Old 01-01-2010, 01:21 PM   #7
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
-Mark.
exactly
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 01-01-2010, 02:41 PM   #8
BlackSunsine
BlackSunsine's Avatar
Drives: 1967 Custom Camaro
Take lots of pics - Before, during and After. Otherwise you will regret it. I sure do from my rebuild. :-(
Current Cars -
1967 Chevrolet Camaro (1983)
2004 Harley Davidson Road King(2004)
Ex 2001 Chevrolet Tahoe (2007) (Totaled Labor Day)
2004 Chevrolet Tahoe (Thursday)
2010 Chevrolet Camaro SS(2009)
Colorado Fall - Beautiful - Cool - Snow is soon!!!
BlackSunsine is offline   Reply With Quote
Old 01-01-2010, 03:21 PM   #9
AK Mike
AK Mike's Avatar
Drives: 1951 Chevy Pickup 2010 Camaro
easy swap
I changed my brother's 6 cyl. '68 Camaro to a 327 Vette engine many years ago; the only thing I needed to change out after the swap was the clutch as we smoked the 6 cyl. clutch on the first road test. Other than that, he drove the car for many years after; just depends on what you want/what you got. The V8 made a 'new' car out of the old base model straight six, that's for sure! Have fun!
AK Mike is offline   Reply With Quote
Old 01-02-2010, 05:16 AM   #10
YenkoSC
YenkoSC's Avatar
Drives: 1967 Camaro RS/SS, 1969 Camaro
I am pretty sure the bodies were not different from a 6 cyl to a ZL1 except for the packages. Drop the V8 in and see what happens.
First Gen Camaro fanatic
YenkoSC is offline   Reply With Quote
Old 01-03-2010, 02:37 AM   #11
BlackZCamaro
No 3rd Gen Lovin.
BlackZCamaro's Avatar
Drives: Seven and counting......
Change Springs, shocks, Radiator, Fan, Fan shroud, accessory drive mounts (aka Alternator, P/steering, P/steering lines, Smog, Water Pump, etc.) and motor mounts to either SB or BB, whatever size motor you're swapping to. You may want to change your heater box and heater core if you go to a BB platform as well. Rear end components come into play as well if you do decide to step up to a BB platform as well, so heed caution if you're on a budget.
Whatever you do, make sure to research it as much as possible for your swap. There's lots of people who have pulled I6 motors to swap V8s, Just make sure you watch the details and you should be golden.
1967 SS 396/375, 1969 327/350, 1969 427/450, 1970 350/360 LT1, 1971 LT1 FI/?, 2000 383 FI Z28, 2002 1SC Z28.
BlackZCamaro is offline   Reply With Quote
Old 01-03-2010, 05:12 PM   #12
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
WOW that guy say you coming a mile away, and you were his sucker for the day.
No offence but he was trying to rob you form your lack of knowledge.
Id almost let him do it, detial everything, then sue him to get it all free for being a jerk like that.
Old 01-03-2010, 05:18 PM   #13
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
^^^ I AGREE 100%.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
2011 Camaro to come in HYDRO BLUE & OLYMPIC WHITE Rickie Camaro Photos | Spyshots | Video | Media Gallery 108 05-27-2010 12:22 AM
The Comaro Betrayed Chevy djljm Off-topic Discussions 36 11-28-2009 08:38 PM
Motortrend: 2010 V6 vs 1967 350 SS christianjax Camaro Photos | Spyshots | Video | Media Gallery 18 09-19-2008 05:25 PM
