Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 02-28-2017, 12:28 PM   #1
gdgraph
gdgraph's Avatar
Drives: 2016 Camaro 2SS
Relocating Wire Harness for Larger Tires
Someone asked for a summary of how to do the wire harness relocation for the driver side rear wheel well when upgrading to larger tires. I uploaded this summary and picture and figured I would share here:
Here's a picture of my driver side rear wheel well. After you remove the wheel well liner you should see a cable that runs in the general path of the red line.
- Remove the wheel well liner by popping out the handful of plastic clips (I only undid the forward half of the liner)
- The yellow marks represent where the cable is secured with a zip tie,
- Cut the bottom 2 that are shown
- Relocate the cable by sliding it inboard as far as it goes (shown by the green line)
- Down at the bottom by the harness connector you will see a frame with a hole that you can run a zip tie through to secure it in it's new location
You can see in the picture where the hole will form from rubbing. This particular picture is from a BFG 305/35/20 on stock springs. Why did I go with a 35 instead of a 30... Because that's all the BFG comp 2 A/S comes in and I wanted to run a 305 size A/S on my 20x11s.
After a few hundred miles the rubbing stopped (didn't get any bigger than what you see below) and no issues with damage to the cable.
gdgraph is offline   Reply With Quote
Old 02-28-2017, 03:44 PM   #2
BurnOne
BurnOne's Avatar
Drives: 2018 Camaro ZL1
Thanks for the write up and Pic!!!!
BurnOne is offline   Reply With Quote
Old 02-28-2017, 03:58 PM   #3
gdgraph
gdgraph's Avatar
No problem!
Old 02-28-2017, 04:06 PM   #4
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
Perfect!!!!
Thanks
JATT
cmeJATT is offline   Reply With Quote
Old 02-28-2017, 04:17 PM   #5
gdgraph
gdgraph's Avatar
Wider Tires = More Fun!
Enjoy!!!
Originally Posted by cmeJATT View Post
Perfect!!!!
Thanks
JATT
Old 03-27-2017, 08:49 PM   #6
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Going to wide for track lol. I had to rerouute the wire today
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails.
Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp
Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85
DELIVERED 12/29/15
http://youtube.com/bybcous " no talking only racing on my youtube"
bybcous is offline   Reply With Quote
Old 03-27-2017, 09:28 PM   #7
gdgraph
gdgraph's Avatar
Wow, that's a huge hole lol
Old 03-29-2017, 12:09 AM   #8
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
How wide did you go?
Sledgehammer70 is offline   Reply With Quote
Old 03-30-2017, 04:38 PM   #9
MrAl
Drives: 2017 Camaro SS 1LE HBM
Is this already done at the factory for 1LE SS ?
Mr Al
MrAl is offline   Reply With Quote
Old 07-12-2018, 01:21 AM   #10
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
Hmmm...was this changed for the 2018 ZL1?
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 07-12-2018, 05:25 AM   #11
Gatorac
Chin Event Manager
Gatorac's Avatar
Drives: 2018 SS 1LE
Mr Al
I'm gonna say no because mine is wearing through the liner right at that spot and i't completely stock.
Jim Pomroy
Chin Track Days Chief Instructor and Event Manager
2018 1LE
2015 Mustang GTPP
2011 Duramax
Access to several Chin track cars...
Gatorac is offline   Reply With Quote
Old 07-14-2018, 08:30 PM   #12
parbreak
Drives: 2017 50th Camaro SS
Just relocated mine last night before mounting 305/45/17 Mickeys for the track.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 07-19-2018, 05:39 PM   #13
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I took my wheel off and did the wire reloaction as directed above. Then I went down to discount tire, after a sweet burnout of course, and had some ps4's installed. (295 in the back)Upon receiving the car, discount tire said it was rubbing the fender well a little bit. So I went home, pulled off my tire and peeled the liner back, cleaned a couple spots on the frame with alcohol, and stuck velcro to the car, then peeled the other side and stuck it to it. I then put the liner back and pressed where the velcro was. I gained maybe an inch of space as there was a gap between the liner and the car. I can now get my fingers behind the tire where before I couldn't. Figured this might help some people from preventing holes in their liner.
Booher is offline   Reply With Quote
Old 08-24-2018, 05:38 PM   #14
SaphfireSS
Drives: 2017 Camaro 1LE SS
Mr Al
No. Had to relocate mine. It’s simple.
SaphfireSS is offline   Reply With Quote
