Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 08-10-2023, 02:46 PM   #71
Drew145022
Drives: 2017 Camaro 2SS Vert
I think I have a good idea, but have no idea how to do this. The plug that goes in the firewall side can the cad file be edited to be able to fit a cable gland? I will add a photo of one if I can figure out how. But it would be perfect for adding wires into the cabin, and it’s also overkill but I still like the idea.
Also added the pic
Drew145022 is offline   Reply With Quote
Old 08-15-2023, 11:59 AM   #72
ctrlz
Here's a link to an old post. I used Hillman plugs which are sold at any hardware store which has a fastener aisle with those little boxes on pull-out shelves.
https://www.camaro6.com/forums/showp...2&postcount=64
Old 01-25-2024, 11:50 PM   #73
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Here is my process: I printed the two plugs out of ABS.
The fire wall connection looks like this with a 10mm nut:
[img]https://hosting.photobucket.com/images/e128/phat_funky_beats/20240124_211949.jpg[img]
The hose connection at the intake pathway looks like this:
And the rubber hose clamps are easily opened and removed as they just use push-clips.
The diaphragm is held with T50 Torx bolts:
With the hose removed, you have this:
The result at the firewall is this piece with butyl gasketing:
The result at the intake pathway is this plug that fits perfectly:
The result is very noticeable. All of the intake noise is gone. The chugging noise from V4 mode is gone. The cabin is much more comfortable.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Build Log: https://www.camaro6.com/forums/showt...6#post11353116
keep_hope_alive is offline   Reply With Quote
