TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 11-17-2014, 09:37 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
RPM TRANSMISSIONS TR6060 - GET YOUR CAMARO5 DISCOUNT!
The Camaro SS has enough power to put a hiccup into your TR6060 from the factory. Spirted shifting can cause the dreaded second gear issue among other problems. Enter RPM Transmissions! They have been building up the TR6060 since they debuted and have been working on the T-56 for years!
RPM STAGE 4 TR6060
RPM STAGE 5 TR6060
RPM STAGE 6 TR6060
Contact us for the best pricing anywhere!!!
Old 11-18-2014, 05:01 PM   #2
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
Can you break out the HP each of these are set up for and let me know what your prices are on each of them?
Thanks
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 11-26-2014, 11:43 AM   #3
Juiced1
A lot really depends on your application. The stock TR6060 can handle some serious power on its own but if you toss on a set of sticky tires and play at the track that changes quickly. Assuming your car will see the track and hard launches we would recommend the stage 5 up to 700 and the stage 6 up to 1000 and the stage 7 which we'll have listed soon for anything beyond that.
Old 12-03-2014, 10:12 AM   #4
Juiced1
Killer trans
Old 12-11-2014, 09:18 AM   #5
Juiced1
Gear up for the track or replace a mistake you may have made.
Old 12-18-2014, 10:01 AM   #6
Juiced1
RPM
Old 12-23-2014, 09:49 AM   #7
Juiced1
Rock crusher
Old 01-02-2015, 09:00 AM   #8
Juiced1
Shift like a boss
Old 01-07-2015, 08:44 AM   #9
Juiced1
BANG GEARS WITH GUSTO
Old 01-07-2015, 09:54 AM   #10
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Just curious, do you guys have an ETA and estimated price on the Level 7. I'm only planning to be around 850ish now, but only want to do the job once and I'm sure I will climb over 1000 sometime.
504hp/478tq
Old 01-13-2015, 03:24 PM   #11
Juiced1
STAGE 7 SYSTEMS AVAILABLE AS WELL.
Old 01-19-2015, 04:17 PM   #12
Juiced1
Killer trans
Old 01-21-2015, 09:09 AM   #13
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Looking for a rpm 1le Trans in stage 5 do you have that need the close ratio
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 01-27-2015, 08:24 AM   #14
Juiced1
PM SENT. SHIFT WITH CONFIDENCE
rpm transmissions, tr6060
