Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-07-2018, 10:03 PM   #1
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
16x20 garage build questions
Hey everyone. I'm going to be having a garage built very soon and I need some input. It has been brought up that I might want to build the walls using 2x6s instead of 2x4s due to the fact that I will be able to better insulate. Can anyone provide insight on this? Has anyone had any success doing it this way? Is going the conventional 2x4 good enoug as going with 2x6 will increase cost.
Thanks in advance and I'm sure more questions will come up. I'm just at the beginning stage and almost ready to submit for my permit.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 07-08-2018, 05:31 AM   #2
BLU DUCE
BLU DUCE's Avatar
I would first check with the building code office to see which is required. Also if they have to be on 16" or 24" centers. Also make it a little bigger that is kind of small. It will fill up faster with stuff than you think.
Mark out a section 16x24 where your going to build it and and park your car in it. This will give you some idea the room in it once the car is in it.
Old 07-08-2018, 10:33 PM   #3
Mike14bumblebee
Thanks Spike. 2x4 on 16 centres is required by code, I assume 2x6 would just be going over the limit lol. I don't have tons of room to go much bigger. My shelter I had the car in the last couple of years was 20x10. So I no my length of 20' is good and the car is less then 7' wide. So potentially I could fit 2 cars in the 16' width. But I do realize that the 16x20 is outside dimensions and it will be smaller on the inside.
Old 07-12-2018, 03:09 PM   #4
Synner
Drives: cars
Unless you plan on heating/cooling the space year round then it's a waste of money for a garage. Yes it insulates better and you can get a higher R-value insulation but do you really need it with a non-heated garage? I don't think you'll really care if it's a smoking hot -5 Celsius instead of a chilly -7 Celsius.
Synner is offline   Reply With Quote
Old 07-12-2018, 07:09 PM   #5
1LEJNG
Drives: Red Hot 2014 1LE
Garage
You will never recover the initial expense in saved heating or cooling energy.
1LEJNG is offline   Reply With Quote
Old 07-13-2018, 07:44 AM   #6
ecreps
Drives: 2014 1LE, 1996 z28
I would agree that it is not worth it, use that money to make it larger. I assume it will not be climate controlled 24/7?
ecreps is offline   Reply With Quote
Old 07-13-2018, 03:31 PM   #7
Fifty 2SS
Fifty 2SS's Avatar
Drives: 2017 Fifty 2SS w NPP
It also depends on how tall the main walls are. For example, here if it is over 12' it has to be 2x6.
Fifty 2SS is offline   Reply With Quote
Old 07-14-2018, 11:59 PM   #8
Mike14bumblebee
Thanks for the responses. Put my permit in with the 2x6 build. Figured it would be better long term. Going with 10' walls. Will be insulated and heated in winter. Not going to cool it in the summer though.
Old 08-12-2018, 02:40 PM   #9
Nb1081
Drives: 10 2ss/rs
You will still notice a temp difference in summer with better insulation the garage will stay cooler than outside we pretty much have same weather im close to lake ontario
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 09-07-2018, 09:33 AM   #10
Mike14bumblebee
Ready for concrete. I no it looks like it’s not level but it was fixed a bit more after the picture was taken.
Old 10-08-2018, 08:39 PM   #11
Mike14bumblebee
Concrete went in 3 weeks ago and my trusses arrived last week
Old 10-08-2018, 08:52 PM   #12
Mike14bumblebee
Started building today. Thought I had enough wood and OSB board but I guess not. Also ran out of daylight anyways.
Old 10-08-2018, 08:55 PM   #13
Mike14bumblebee
At the end of the day. Also still have to get my doors.
Old 10-09-2018, 04:19 PM   #14
X77-69z28
X77-69z28's Avatar
Drives: 69 Z/28, 70 Z28, 99SS, 15 Z/28 2018
Nice work. I hope you polished the concrete floor!
Buddy
69 Z/28 burnished brown, m-21 owned since 1978
70Z/28 forest green M40 CE block PROJECT
99 SS hugger orange 6spd no t-tops 1 of 54
15 Z/28 white AC, radio
X77-69z28 is offline   Reply With Quote
