Roto-Fab
Old 12-25-2013, 06:57 AM   #1
burnn1
Burnn1
burnn1's Avatar
Drives: 2011 2LT
Angry 2011 V6 Burns Oil
72,000 highway miles on my 2011 V6. This summer, she started burning oil at about a quart every 3-4 tanks of gas - almost as bad as my Vega did way back when. Garage floor is clean - unlikely it's a leak. Dealer says "it happens on older cars - Chevy recommends checking oil every time you gas up". I think this is BS and should dump her. Auto Zone says use Lucas Stabilizer.
Thoughts?
burnn1 is offline   Reply With Quote
Old 12-25-2013, 08:21 AM   #2
mikeyg36
Drives: 2015 Z/28 #533
Probably a stretched timing chain. I know the LLTs have issues with burning oil and stretched chains.
Old 12-25-2013, 09:44 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
This. Common issue on the LLT, do a search and you'll come across many threads.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 12-25-2013, 10:35 AM   #4
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
FYI.......The stretched chain has nothing to do with the burning of oil.
2 separate issues.
Best thing you can do is change the oil often, every 3k - 5k miles, do not follow the DIC.
If you read some of the GM information they report that burning 1qt. / 1000 miles is normal.
I am at 59K miles and just now seeing I am losing about 1/2 qt. per oil change.
Also depends on how far you drive per start up. The more you can get the oil to operating temperature to burn of moisture the better it is for everything.
rtcat600man is offline   Reply With Quote
Old 12-25-2013, 10:53 AM   #5
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
2 separate issues.
My timing chain went at around 34,000 miles and my Camaro never burned any oil. Oil changes were done when the DIC read about 20% life left. I did not feel comfortable driving 6000-7000 miles on an oil change.
2024 Camaro SS convertible
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
philthy is offline   Reply With Quote
Old 12-25-2013, 11:43 AM   #6
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Thoughts?
Either dump it or drive it hard and destroy the engine before the 100k mi warranty ends. Just make sure you have oil in it when its towed to the shop.
shrinkdoc is offline   Reply With Quote
Old 12-25-2013, 11:46 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
2 separate issues.
I always thought if the chain was stretched you'd burn more then the normal amount of oil.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 12-25-2013, 12:12 PM   #8
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
I think it's the other way around. Low oil (from whatever cause) leads to timing chain issues.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 12-25-2013, 11:03 PM   #9
mikeyg36
That's what I thought
Old 12-26-2013, 06:12 AM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Two separate issues. The mysterious disappearing oil and stretched timing chain. Now dirty oil can lead to the chains stretching sooner, hence GM changing the Oil Life Monitor for sooner oil changes.
As for the mysterious disappearing oil... that normally leads to a spun bearing and trashed motor...
scrming is offline   Reply With Quote
Old 12-26-2013, 10:02 AM   #11
KMPrenger
KMPrenger's Avatar
I believe this is a large part of it.
Doing short trips in these engines leads to an excess of moisture and gas in the oil which will lead to other issues which I'd guess includes bearing and chains failing.
I'd love to know the driving habits of those whose chains went out early.
It is a design flaw in my opinion, but if the engine is ran long enough to burn up the gas/moisture during each drive my understanding is that this greatly reduces the chances of failures.
But yes...definitely keep an eye on your oil level and don't let it drop.
Old 12-26-2013, 12:37 PM   #12
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
check your spark plugs. Somebody had issues with the valve guides wearing out
Sikoriko is offline   Reply With Quote
Old 12-26-2013, 01:16 PM   #13
mikeyg36
That's messed up that it has this many problems. I was looking at a V6 before I got my car and these timing chain issues are what drove me away from it. I lucked out in the long run but I feel bad for everyone that got screwed over with this engine.
Old 12-26-2013, 01:54 PM   #14
rtcat600man
Interesting, that is the first I ever heard of this one, and I have been following this forum for over 4 years now.
burn, oil, v-6
