Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 06-19-2016, 04:53 AM   #1
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
V6 to V8 Rotor help
I have a 2011 V6LLT and it's time for some new rotors but i came across some aftermarket and stock V8 rotors for a good price. Will V8 rotors fit with the V6 calipers and break pads? I know sometimes the rotors can differ in size so before I bought anything I wanted to check with you all. Btw I have 20's on the car.
I've prolonged this long enough and my rotors are bad so I would like to order asap. If anyone has any experience in this please let me know. Thanks!
Mvp_Me is offline   Reply With Quote
Old 06-19-2016, 06:20 AM   #2
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
NO!!! SS rotors don't fit a V-6!
Eddiefuzz is offline   Reply With Quote
Old 06-19-2016, 06:32 AM   #3
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
You have to get SS calipers for it to work and I believe your wheels need to be 18" or larger to fit, someone will clarify if that is correct.
45thCamaro is offline   Reply With Quote
Old 06-19-2016, 10:02 AM   #4
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Thanks for the help, definitely saved me a great deal of disappointment lol
Old 06-20-2016, 01:52 PM   #5
seanjhon
seanjhon's Avatar
Drives: 2013 camaro
Yes you would definatley need to upgrade the whole brake system if you plan on upgrading your rotors. You would need to trim the dust shield on the rear wheels about 2 inches in order for the rotors to slide on. The fronts are good as there is no modification needed or trimming
But as the poster said above you would need 20 inch rims and tires in order for the calipers to clear, presuming you you upgrade the whole package. You also would need to get the ss brake lines OR stainless steel lines as the ss lines are longer i believe.
I did the upgrade on my camaro, so feel free to ask any questions.
seanjhon is offline   Reply With Quote
