Old 04-21-2023, 01:57 PM   #1
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
60-130 times
What are your 60-130 times along with your mods and whp.
So far mine in 7.26 spinning and mods are cam, headers, lower pulley. Making 707rwhp on a cold pull
Nimair.ZL1 is offline   Reply With Quote
Old 04-21-2023, 02:07 PM   #2
Future1LE
Drives: 2020 Chevy Camaro ZL1 1LE
My Zl1 with the magnuson 2650, 103 TB, Rotofab big gulp, and dsx aux pump tune on 93 made 670whp. Stock headers, stock hpfp and injectors. I ran a 6.6 60-130 in -400 DA. I just finished installing toohighpsi port injection, headers, 85mm upper pulley. Hopefully mid 5s 60-130 after the tune is done.
Future1LE is offline   Reply With Quote
Old 04-21-2023, 02:54 PM   #3
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Here is one that's kind of CRAZY fast 3.68 seconds :
https://www.instagram.com/p/CYCXYvOLmah/?img_index=1
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 04-21-2023, 03:25 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Using the HPT scan of my 9.61 run:
0-60 = 2.64
60-130 = 5.41
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 04-21-2023, 03:40 PM   #5
Z OH 6
Drives: 2021 Red Hot ZL1
No point in testing if you're spinning. Need traction to be accurate.
Z OH 6 is online now   Reply With Quote
Old 04-21-2023, 04:44 PM   #6
SIC LSX
Drives: 2018 Camaro ZL1
7.38 with a rotofab big gulp and flex fuel tune on E50. 606rwhp
SIC LSX is offline   Reply With Quote
Old 04-21-2023, 09:55 PM   #7
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf GTI
Lol don’t you think he’d prefer not spinning? Wouldn’t everybody? That’s like posting a time and then saying you need to shift better to be accurate. Well… Of course…
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT
PowerDemon is offline   Reply With Quote
Old 04-22-2023, 09:55 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I have tuned a few bolt-on flex fuel cars and they all run in the 6.6-6.8 range on the street in 500-1500da. I have one ported blower(14psi), headers, cai, e60 car that ran low 6's. These are full weight cars in full street trim on factory wheels with a 20" dr. A cam car should run break into the 5's in decent air with traction. rolling from 50 on the street vs a solid launch at the track(this will net a little faster 60-130 as well). Negative DA makes a huge difference. So, make sure you are comparing apples to apples because the internet likes to compare lemons to watermelons.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-22-2023, 11:02 AM   #9
Z OH 6
He's losing a ton of time was my point. No sense comparing times if he's got no traction. He needs to solve that first.
Old 04-22-2023, 11:25 AM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
My area had negative DA... 70M years ago!
'20 ZL1 1LE A10,
Old 04-22-2023, 11:53 AM   #11
Nimair.ZL1
When my 60-130 was done it we started at 56-57 mph. Also spun off the hit. In good weather and if I could hook I’d think I would run a 6.5-6.7 60-130. If I were to port the blower then I would be into the 5.9 range. Car was also pulling timing up top cause of MAT
Old 04-22-2023, 06:14 PM   #12
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
If you roll into the throttle from 40ish and at wide open by 55 you can get better times. Gotta transfer the weight to the back before you stab it.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 04-22-2023, 07:37 PM   #13
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
I have been faster since, as my car makes more power now.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 04-22-2023, 08:51 PM   #14
Nimair.ZL1
What mods?
