04-12-2022, 11:40 PM | #1 |
New build in the works 1100rwhp
Welp, decided to bite the bullet and just go full out on my car instead of buying another ZL1 and ripnning that apart. I'm eyeballing a c6 Z06 to gut that for track only, but i'm looking for 1100+ wheel on my ZL1. So far here is the list with a few questions.
LME 416ci 1800HP Longblock (iron) Callies Magnum Crankshaft Callies Enforced Rods w/ARP Ultra Hardware Diamond 2K Pistons w/Upgraded Wrist Pins ARP Main Studs LME Bracketry Adapter CID Aftermarket LT4 Heads LME Titanium Intake Valves Inconel Exhaust Valves LME Dual Spring Kit Custom LME Camshaft LME Billet Timing Cover ARP Head Studs Cometic Head Gaskets C5R Timing Chain Johnson Lifters 10L90 complete Rebuild New Driveshaft TooHigh PSI Spacers Deatschwerks Injectors Custom Holley Port Injection Keeping my blower/interchiller Question on the toohigh psi spacers/port injection. Anyone else using this setup here with the holley system, and how is it? I should be able to run full E with my low side upgrades. Any issues or concerns? 10 Rib and 112mm throttle body are options too. I believe the trans can take about 1200whp after the rebuild so thats the max im going to shoot for.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
04-13-2022, 01:16 AM | #2 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Don't forget the all season tires so you can drive it in the snow.
In all seriousness, that is going to be one hell of a build. Keep me posted on it. |
04-13-2022, 01:23 AM | #3 |
What are you planning to do with the current engine?
04-13-2022, 04:21 AM | #4 |
112mm TB and 10 rib are no brainer upgrades IMO. Bore is more important than stroke with a PD blower, I’d look at a 4.125” bore instead of stroking a stock bore motor too. Looks like a killer build!
04-13-2022, 05:23 AM | #5 |
10 rib for sure.
04-13-2022, 05:44 AM | #6 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Jason Leiva, has a similar setup with the Toohigh plates, and Holley, but with a billet block, and also a built 10speed Pure transmission. https://m.facebook.com/groups/718885...6529636178463/
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-13-2022, 05:58 AM | #7 |
To be honest, since there aren't very many people pushing a ZL1 to this level, I don't know that I would trust too many opinions here. I would contact Jason Leiva on FB and ask his opinion. He owns the worlds quickest 6th Gen ZL1 and he just got finished with his latest build which is 1445whp. He's super friendly and always willing to help answer questions.
https://www.facebook.com/leiva.jason https://www.facebook.com/groups/7188...2032327961527/ |
04-13-2022, 06:21 AM | #8 |
Drives: 2022 ZL1 Join Date: Dec 2021
Save your money
Call Hennessy |
04-13-2022, 07:30 AM | #9 |
04-13-2022, 07:35 AM | #10 | |
A lot of people might have useful information but without pushing this far they might not have the best information. At this level, 1200 1300 1400 RWHP, there are a lot of things involved. I certainly have no advice to give. Lol. |
04-13-2022, 07:44 AM | #11 | |
Dyno Show Queen LOL
Other than that looks solid... I take it its going to be just a race car?
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 04-13-2022 at 07:56 AM. |
04-13-2022, 07:51 AM | #12 |
Lol!! Is this JSH other account?
Calling Hennessey is last thing I would ever do. (Make that never)
04-13-2022, 08:08 AM | #13 | |
As far as the plates though, what other options are there really with the magnuson?
04-13-2022, 08:31 AM | #14 |
Looks solid other then I would do a 427 instead of 416.
Jenetty has a build documented making almost 1100whp on E82 with a 427/2650 combo using DI fueling(XDI system).
2016 NFG 1SS A8
