05-02-2023, 08:03 AM | #1 |
ET Street R Air Pressure
How low can I go at the strip? 14, 15, 16?
'20 ZL1 1LE A10,
05-02-2023, 09:08 AM | #2 |
I am guessing 16-18psi. Slicks you would run lower but I don't think a drag radial would like it.
2016 NFG 1SS A8
05-02-2023, 01:10 PM | #3 |
I've been running them around 16 lb. Maybe 15 and a half because my air gauge is old and reads a little low so 14 and 1/2 equals 16 lb
'20 ZL1 1LE A10,
05-02-2023, 03:06 PM | #4 |
Drives: 98 Camaro Join Date: Apr 2022
Heavier car on a good track you should be 18-20psi
05-03-2023, 06:53 AM | #5 |
I talked to MT techs at Alanta Tvs shootout a few years back and they told me 19 to 20 psi since the car and driver was 3900 lbs. That's about where I ran the Street Rs all season long. I run my Hoosier slicks at 15 psi on my Lt1 Camaro.
05-03-2023, 08:12 PM | #6 |
Drives: Turbo 6.2 Join Date: Feb 2019
I set mine to 18 cold. I bet they gain a lb or 2 after burn out.
17”
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
05-03-2023, 08:22 PM | #7 |
I ran my 17” beadlocks the same way.
05-03-2023, 08:29 PM | #8 |
All five of my hits have been at 16#
'20 ZL1 1LE A10,
05-03-2023, 08:30 PM | #9 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
I never go that low. 24-26 usually. Do a burnout to first smoke then drive it out. The car will hook. No need to go that low at all.
05-03-2023, 09:26 PM | #10 |
Cold 15#s. Have gone 1.31-1.34 60ft on a handful of passes.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
05-03-2023, 10:09 PM | #11 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
When I ran ET Street R’s it was around 22. That is where we’ve been on the Radial Pro’s also. We recheck at every pass - going into and while in the lanes if it’s hot and sunny.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
05-04-2023, 04:06 PM | #12 |
What pressure would you run 305/45R17 at on the road?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 05-04-2023 at 05:27 PM. |
05-04-2023, 04:20 PM | #13 |
Drives: 18 Camaro 2SS Join Date: Jul 2022
Tire pressure
18 track 32 street
05-04-2023, 06:32 PM | #14 |
I put 30 in them before leaving the track
'20 ZL1 1LE A10,
