04-21-2023, 01:57 PM | #1 |
60-130 times
What are your 60-130 times along with your mods and whp.
So far mine in 7.26 spinning and mods are cam, headers, lower pulley. Making 707rwhp on a cold pull |
04-21-2023, 02:07 PM | #2 |
Drives: 2020 Chevy Camaro ZL1 1LE Join Date: Nov 2017
My Zl1 with the magnuson 2650, 103 TB, Rotofab big gulp, and dsx aux pump tune on 93 made 670whp. Stock headers, stock hpfp and injectors. I ran a 6.6 60-130 in -400 DA. I just finished installing toohighpsi port injection, headers, 85mm upper pulley. Hopefully mid 5s 60-130 after the tune is done.
04-21-2023, 02:54 PM | #3 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
https://www.instagram.com/p/CYCXYvOLmah/?img_index=1
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
04-21-2023, 03:25 PM | #4 |
Using the HPT scan of my 9.61 run:
0-60 = 2.64 60-130 = 5.41
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-22-2023 at 08:15 AM. |
04-21-2023, 03:40 PM | #5 |
04-21-2023, 04:44 PM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Mar 2013
7.38 with a rotofab big gulp and flex fuel tune on E50. 606rwhp
04-21-2023, 09:55 PM | #7 |
Drives: Camaro ZL1, Golf GTI Join Date: Feb 2022
Lol don’t you think he’d prefer not spinning? Wouldn’t everybody? That’s like posting a time and then saying you need to shift better to be accurate. Well… Of course…
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT |
04-22-2023, 09:55 AM | #8 |
I have tuned a few bolt-on flex fuel cars and they all run in the 6.6-6.8 range on the street in 500-1500da. I have one ported blower(14psi), headers, cai, e60 car that ran low 6's. These are full weight cars in full street trim on factory wheels with a 20" dr. A cam car should run break into the 5's in decent air with traction. rolling from 50 on the street vs a solid launch at the track(this will net a little faster 60-130 as well). Negative DA makes a huge difference. So, make sure you are comparing apples to apples because the internet likes to compare lemons to watermelons.
2016 NFG 1SS A8
04-22-2023, 11:02 AM | #9 |
He's losing a ton of time was my point. No sense comparing times if he's got no traction. He needs to solve that first.
04-22-2023, 11:25 AM | #10 |
My area had negative DA... 70M years ago!
'20 ZL1 1LE A10,
04-22-2023, 11:53 AM | #11 |
When my 60-130 was done it we started at 56-57 mph. Also spun off the hit. In good weather and if I could hook I’d think I would run a 6.5-6.7 60-130. If I were to port the blower then I would be into the 5.9 range. Car was also pulling timing up top cause of MAT
04-22-2023, 06:14 PM | #12 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
If you roll into the throttle from 40ish and at wide open by 55 you can get better times. Gotta transfer the weight to the back before you stab it.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
04-22-2023, 07:37 PM | #13 |
I have been faster since, as my car makes more power now.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
04-22-2023, 08:51 PM | #14 |
