Old 11-14-2022, 01:17 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Ron_Robinson1 View Post
Ahhh my bad. Sorry brother, honestly. Took the message wrong as I was reading others as well.
It's all good..
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 11-14-2022, 01:25 PM   #16
Z OH 6
Drives: 2021 Red Hot ZL1
Originally Posted by KingLT1 View Post
That price includes the reflex plus and has proven to be very capable and easy to tune. I don't know what you mean by preferred, but it hasn't been out long enough for those using Holley to prefer one or the other. I suppose once it gets wideband support some bigger name shops might switch to it.
Correct, when and if.
Z OH 6 is offline   Reply With Quote
Old 11-14-2022, 02:04 PM   #17
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
The Toohighpsi is the ticket for sure. I know some tuners don’t want to use it yet because of the wideband. Others have used it with great results.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 11-14-2022, 02:05 PM   #18
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Finally reached your goal?
Haha, I know you better than that
C'mon, what's next?
Old 11-14-2022, 02:15 PM   #19
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I wonder why people don't want to use it? I mean, if I understand it correctly, isn't it just using the MAF freq. to control the injectors? Are people hesitant because it's not closed loop with a wideband?
I mean, that's no different than any (non-c8) stock GM system in open loop from that aspect.
I'd have no issue with it. Dial it in, and "let 'er rip tater chip"
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 11-14-2022, 02:25 PM   #20
KingLT1
KingLT1's Avatar
It doesn't necessarily need wideband support. It's been working great for those currently running it.
2016 NFG 1SS A8
Old 11-14-2022, 02:42 PM   #21
Ron_Robinson1
My real take is change. Most people don’t like change and if used to doing things one way why learn another. Just like tuning with meth. Some like to some don’t.
Reminds me when ID injectors came out on the LS cars. Some shops only wanted to use them after because of the injector data that came with them. FICs are half the price but don’t come with data making them easier to tune.
Old 11-14-2022, 03:14 PM   #22
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Nice one rob. I’m Going port injection too on a fully built lt4. It’s still in the shop.
How much power is it making now?
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 11-14-2022, 03:51 PM   #23
Ron_Robinson1
Thanks man, I look forward to see your build.
We only only dynoed the car in 6th gear. So these numbers are a little lower compared to the 1:1 7th gear. Mustang 959/831.
Old 11-14-2022, 04:09 PM   #24
Z OH 6
Understood, but most shops prefer a wideband.
Old 11-14-2022, 05:09 PM   #25
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
GREAT work Ron! Awesome stuff.
Old 11-14-2022, 05:17 PM   #26
Ron_Robinson1
Thanks buddy. Much appreciated.
Old 11-14-2022, 06:00 PM   #27
KingLT1
KingLT1's Avatar
Why? It's maf controlled, can see ethanol, and you still use a wideband in the exhaust to tune like you would with anything else that is open loop.
Dedicated wideband would allow for closed loop fuel control so it will self correct. Yeah that would be nice but GM stuff has been going plenty fast with Open loop fueling for years.
2016 NFG 1SS A8
Old 11-14-2022, 06:55 PM   #28
Joshinator99
Can I ask what you did to get such a good 60’ time? I see you mentioned the 15” conversion, did that make a big difference? Are you launching in 1st or 2nd (assuming still on 10L90)? That 60’ time is what I need to get to 9.0 flat or better.
