BeckyD @ James Martin Chevy
Old 10-26-2022, 07:45 PM   #1
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Front Sway Bar
Has anyone in here removed front sway bar? If so how hard is it.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 10-27-2022, 06:38 AM   #2
Drnick
Drives: 22’ ZL1
Why do u want to remove??
Drnick is offline   Reply With Quote
Old 10-27-2022, 07:22 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It's not difficult.
The biggest thing is if you're doing in on the ground, you'll need to get the front end pretty high, because you'll have to drop the shear panel. But - in order to drop it, there is a hook on the front, that is "hooked" so much that the panel has to swing probably beyond 90* front datum. You can cheat a bit by bending it, because it, too, is aluminum, once you get it lowered enough. After bending it slightly, you won't need to drop it the 90*.
I think that hook is there for assembly, really. I wouldn't advocate bending much of anything, but this is one I think is NOT a big deal at all. It's that hook, though, that makes it tough, if you're doing it on the ground. If you have access to a lift, you won't have to do this.
Otherwise - it's as straight forward as any other sway bar install. The rear is more complicated, though, if you have stock exhaust...
'20 ZL1 Black "Fury"
Old 10-27-2022, 07:42 AM   #4
Ron_Robinson1
Originally Posted by radz28 View Post
It's not difficult.
Thanks for the advice. Much appreciated.
Old 10-27-2022, 07:49 AM   #5
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I was wondering the same thing. Thanks for bringing this up.
Drag strip weight transfer at launch.
It's not difficult.
Thank you sir!
Old 10-27-2022, 08:47 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thank you sir!
