09-27-2019, 12:39 PM | #1 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Pray Performance ported intake manifold.
I purchased a stock intake manifold and sent it to Brett at Pray Performance for porting. Brett was pretty quick about porting the intake manifold and getting it back to me. With both manifolds on the bench I took photos for comparisons sake. Bolted the ported IM on the car and drove it home. Throttle transition seems to be a little smoother, but that is completely subjective. Honestly can't tell if the car is faster, but will hit the dyno at Superior to compare-sometime in the next couple of weeks.
Before and after:
Bolt-ons.
09-27-2019, 02:38 PM | #2 | |
Black lightning
PTB you will the throttle response more pretty sure
[ 2021 Camaro ZLE 10 speed
09-27-2019, 02:46 PM | #3 |
Drives: 2017 SS 1LE Join Date: Sep 2011
Mine made 18whp with PTB and 2nd cat delete. Definitely a bit faster, but not an earth-shattering difference..
2017 1SS 1LE - Eibach Springs | Pray IM | Katech TB | Borla 60606 | Corsa Extreme | E85 Flex Tune
09-27-2019, 02:59 PM | #4 |
Drives: Camaro Join Date: Apr 2017
If you can't just feel the additional power it probably wasn't worth it.
09-28-2019, 11:05 AM | #5 |
Drives: 2018 Camaro ss Join Date: Jul 2019
wondering how that compares to the the msd manifold. 1200 and gets you 20ish hp gain. How much was the porting service?
09-28-2019, 11:36 AM | #6 |
Whether you use FB or not, Google Pray’s page and see what he’s building. This post does list his fees. It might have been updated but it gives you an idea of what it will cost.
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
09-28-2019, 12:36 PM | #7 | |
From a purely subjective perspective, the car does feel faster. Throttle response appears to have improved. The car feels like the ported intake manifold woke up the engine; I can't define my impressions any better than that. The proof is in the pudding as they say, so the dyno will be the ultimate arbiter of this debate. Once I have the data that proves/disproves the gains the Pray Ported intake manifold provided, I am going to add a Soler Performance 95 mm throttle body and have the car completely retuned.
Bolt-ons.
09-28-2019, 01:32 PM | #8 |
Msd will give you a tenth and 2mph over a ported stock intake. If you have a auto and/or roll race it’s a no brainer, it rips from a roll. Also it is a MUST have if you’re gonna cam it, something like 30-40hp there. If a cam is a possibility might as well get one from the start
10-03-2019, 03:35 PM | #9 |
Pray Performance
So the car went back to the dyno to assess any gains/losses. Peaks HP/TQ picked up 4 HP/2 WTQ. Gains everywhere, but not large gains. As I stated previously, throttle response and throttle transitions are smoother. The car 'feels' better, but honestly, the dyno does not reflect that. Interpret the data how you will.
Bolt-ons.
10-03-2019, 03:58 PM | #10 |
ported stock IM makes more power across the entire curve.
2016 NFG 1SS A8
10-03-2019, 04:38 PM | #11 |
After looking on a computer, the fuel looks like it moved. Wonder when you lean it back out to where the blue line is, if it would gain another 5hp and get you the 10hp
10-04-2019, 12:57 AM | #12 |
Drives: like an old lady Join Date: Jun 2012
op: what else is done to the car?
2016+ camaro: everyone’s first car
10-04-2019, 11:46 AM | #13 |
Drop in Green Filter. Soler Performance throttle body. Flex fuel kit. Tune. Finally Pray Ported IM.
Bolt-ons.
10-04-2019, 12:03 PM | #14 |
sweet. pretty much exactly what i have planned for mine. although the ported stuff doesn’t appear to be worth much. about $100/hp + parts.
