09-13-2023, 08:49 AM | #1 |
Drives: Chevrolet Camoro Join Date: Aug 2023
Wheel Offset
I have a 2014 RS. I want to swap out the wheels. Can someone explain offset to me? I found a set I like that is staggered 20x10 an 20x8.5 with 0 offset. Will these work? They are 5x4.75 bolt pattern. From what i have figured out online that is basically the same at 5x120. Is that correct? Sorry if this is a dumb question that has been covered.
Thanks |
09-13-2023, 06:49 PM | #2 |
Drives: 2012 camaro ss Join Date: Sep 2018
No Offsets are wrong!
GPI Powered
09-14-2023, 08:53 AM | #3 |
Drives: '20 Corvette Stingray Join Date: Jul 2009
In the WHEEL and TIRE section, here id a thread that explains OFFSET. heres a direct link to it.
https://www.camaro5.com/forums/showthread.php?t=111604
09-21-2023, 03:17 PM | #4 |
Drives: 2016 1SS Join Date: Apr 2012
Offset on ar 20x10 Rear Wheel for a 5Gen Camaro needs to be +35mm.
09-21-2023, 08:19 PM | #5 | |
Drives: Camaro Z/28 Join Date: Sep 2023
09-25-2023, 10:11 AM | #6 |
We recommend a 20x9 for the front also in a either a 27mm or 35mm offset
11-23-2023, 07:48 AM | #7 |
Drives: 2013 Camaro Convertible Join Date: Jan 2015
What about a 20x10 square set up? Will 35offset work?
11-25-2023, 06:09 PM | #8 |
Drives: 2012 Camaro 2SS Join Date: Jun 2023
https://tiresize.com/wheel-offset-calculator/ Play around and see what fits. It is based on tires size since, unless your running stretched tires, they protrude past the wheel, typically. If you know what's on it now you can see how changes will effect fit. |
11-25-2023, 06:50 PM | #9 | |
