BeckyD @ James Martin Chevy
Old 07-20-2023, 11:44 AM   #1
RyPG
Drives: 2018 camaro zl1
What’s best route for power?
So my 2018 a10 zl1 at the moment has long tube headers, intake, and 93 tune.
For next set of mods and tune. I was going for lower pulley and e50(flex fueld and auxiliary pump) with the might mouse catch can and cordes expansion tank i i just ordered but i heard changing the pulley will give me heatsoak so i did some research and
Now i dont know if it’s better only e50 and pulley or get stage x ported, e50 with or without the pulley. This will be my last batch of mods done to this car and I pretend to go to tracks and dragway so i want the at least amount of problems and heat. If you know the best way to minimize heatsoak and more power. Please let me know thank you!
RyPG is offline   Reply With Quote
Old 07-20-2023, 01:09 PM   #2
2017whippledzl1
Drives: 2017 zl1
What kind of power are you looking for? I'm parting out my zl1 currently and was making 823 to the wheels on a fairly moderate tune
2017whippledzl1 is offline   Reply With Quote
Old 07-20-2023, 01:34 PM   #3
Caerus
Caerus's Avatar
Drives: 2023 Camaro ZL1
You need a Magnuson TVS 2650 supercharger upgrade. Please read this thread:
https://www.camaro6.com/forums/showthread.php?t=543933
The 2650 can sustain full throttle for a lot longer due to (from JANNETTYRACING):
A) higher efficiency at higher volume
B) massive super efficient intercooler bricks.
2023 Camaro ZL1 6MT Summit White
Caerus is offline   Reply With Quote
Old 07-20-2023, 02:11 PM   #4
ZLRob
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
5% on stock fueling will be the absolute most you want to go and still be able to run E50-60 at most.
You will need a JMS booster or something to be able to allow the low side to keep up with the additional fueling demand of E. ATI makes a 5% 8.43 pulley.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ
ZLRob is offline   Reply With Quote
Old 07-20-2023, 10:27 PM   #5
RyPG
i want to between 650whp to 700whp. nothing more i dont want to sc or add a interchiller. i want as close to 700whp without any issues with heatsoak or spending too much because i want to go tracks and dragway.
Old 07-20-2023, 10:31 PM   #6
RyPG
there is no better route to get as close as i can to 700whp without adding a interchiller or upgrade sc?
Old 07-21-2023, 07:40 AM   #7
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
You don’t have to pulley to make power. But to do it without the pulley you need flex fuel, porting, injectors, HPFP and low side help. That isn’t the cheapest way to go but it gets you there without adding heatsoak.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
CW3SF is offline   Reply With Quote
Old 07-21-2023, 10:27 AM   #8
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I don't think I'll ever power mod my ZLE, but if I did I've always thought if you want a significant gain with minimal heat issues (and more power always = more heat) I would start with this... +125 WHP = about 800 HP and would make a ZL1 feel a lot more powerful, from scary to very scary, and give you a real edge on road course down straights over exotics. No injectors, no extra fuel pump just a voltage booster.
Jannetty Racing--JRE 125 RWHP FLEX FUEL Performance Package
-Flex Fuel Sensor Kit
-Kooks 1 7/8" Longtube Headers Ceramic Coated
-Kooks Green Cats
-Roto-Fab Air Intake System
-JMS Voltage Booster
-HP Tuners MPVI 2 with all required custom tuning by JRE
-LT5 Throttle Body Conversion Package
-MSD Spark Plug Wires
-NGK Spark Plugs
SFV1LE is offline   Reply With Quote
Old 07-21-2023, 10:35 AM   #9
Caerus
Caerus's Avatar
You need to go to the correct forum to discuss this (forced induction). Lots of good information there via; searching and reading threads and start a new post there. You will get better results there. Good luck.
https://www.camaro6.com/forums/forumdisplay.php?f=236
Old 07-21-2023, 12:17 PM   #10
SFV1LE
Are you saying that every question about adding power to a ZL1 should go to the low viewer/low response FI forum?
You might get some additional info on the FI forum, but I've been on here since I bought by ZLE in 2018 and a question like this about basic power mods seems like the most common and popular kind of basic topic ZL1 owners ask and enjoy discussing.
All ZL1s are FI, what should we limit our discussions to on this main ZL1 thread? I see many mechanical/engine/power topics here.
I think this is where a new owner is more likely to get more info faster due to the number of viewers and volume of posts.
Old 07-21-2023, 12:39 PM   #11
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Yep. And a quick google search of "camaro6 zl1 power mods" returns a TON of threads to review.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
help me i'm a noob, mods, power, pulley, zl1
