Old 11-25-2018, 06:05 AM   #1
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Convertibles and car washes
Here in NJ we had heavy rains that should have washed most of the salt off the roads and the temperatures will be above 50 degrees. The Camaro will be coming out of the cave.
At the end of the day I'd like to take the Camaro to the car wash, mostly for the undercarriage wash. Are there any cautionary tales about taking a convertible through an automatic car wash?
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 11-25-2018, 09:14 AM   #2
VJChevelle67
The Beast
VJChevelle67's Avatar
Drives: 2016 2SS Camaro Convertible
Don't do it
The tires are to wide for one. Specially if it's a SS or a ZL1. Or if it's been modified with wider tires look in your manual it should mention it there that's where I seen it first. That the ones with the tire guides . The others should be fine. I wash mine by hand so I don't have to worry . So don't take the chance. Enjoy your ride.
VJChevelle67 is offline   Reply With Quote
Old 11-25-2018, 10:47 AM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
There are a few completely touchless car washes here that don't have the tire guides and I will occasionally go there. Unfortunately they bundle the belly blaster in a package with other items like spray-on wax that I prefer not to use on the convertible top. I will probably build or buy a belly washer to use at home for this reason. Check the car wash to see what they include and decide if you want the package.
Mark114 is offline   Reply With Quote
Old 11-25-2018, 11:01 AM   #4
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Don't leave the top down. Make sure it is up....J/K!!!!!!!!!AAAAAAAAHHHHHH!!!!!
Old 11-25-2018, 11:16 AM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Run it thru a touchless wash, protect the top with RAGGTOP or 303 products...google them...
Old 11-25-2018, 01:55 PM   #6
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
You could invest in a good power washer, they are worth the money. You can drive it and before you put it away wash off underneath and put it away. There are different pressure nozzle, use the wide spray nozzle and you can do a really good job underneath. To even do a better job run it up on some ramps or jack it up on one side and you can get all of it off.
Old 11-25-2018, 02:19 PM   #7
Cchief
Cchief's Avatar
Drives: 2017 Fifty 2SS Convertible
My vert is dusted after each use, for my other cars, I use a long handle soft brush in the cold months, also here in NJ
2017 2SS 50th anniv. vert.
2017 Jeep Laredo Altitude
2018 MB GLE350
Cchief is offline   Reply With Quote
Old 11-25-2018, 04:25 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Car wash? Car wash?
No way am I putting my Camaro through a car wash...and it's not even a convertible.
The OP mentioned that their Camaro is in a cave for winter. That's a good place for it to stay until sand and salt season is over.
Old 11-25-2018, 04:48 PM   #9
redcoats1976
we bought a long metal tube(approx.2')that screws unto the hose and concentrates the water stream almost like a pressure washer.only cost like 10 bucks,and it would probably blast the salt off the undercarriage pretty good.
Old 11-25-2018, 07:52 PM   #10
enzia35
Drives: '16 Garnet Red 1SS
I read a story about a guy obsessed with his car, ran it through the under carriage cycle at the car wash...turns out the water was recycled from previous washes.
Not sure if true or not, just funny.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 11-25-2018, 08:50 PM   #11
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
The ones around here filter and reuse the water.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 11-25-2018, 11:14 PM   #12
somedude
somedude's Avatar
Drives: 2017 Camaro 1LT Convertible Auto V6
I would not do it, hand wash only.
https://www.camaro6.com/forums/showthread.php?t=437535
https://www.camaro6.com/forums/showthread.php?t=454761
https://www.camaro6.com/forums/showthread.php?t=487403
https://www.camaro6.com/forums/showthread.php?t=478331
somedude is offline   Reply With Quote
Old 11-26-2018, 05:16 AM   #13
TybeeSS
Drives: 2017 2SS Auto
Ran my leased SS through an automatic car wash probably 50 times without issue. I wouldn’t recommend them for reasons that apply to any car including hard tops but had no issues with leaks or damage to the top if that’s what you are concerned about.
TybeeSS is offline   Reply With Quote
Old 11-26-2018, 05:44 AM   #14
Rock-It Man
Yes, there have been reputable news stories about the re-use of water by car washes.
How do you filter out dissolved salt?
