Vararam
Old 04-07-2012, 07:30 PM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
oil leak
So today after having my car pakred for over 2 weeks, I found some oil on the floor in the garage. It was fresh. I did a oil change back in october and had some oil spilled out. Right after the oil change, i parked my car for almost 4 months and i did find some oil then which i expected. I cleaned as much as i could from the car. I have driven the car a few times after that oil change. You guys think that oil i found today is from what i spilled or a leak??? I do have a catch can but there is no oil near where the small hose to drain sits on the engine bay and i had double check to make sure the drain valve is closed all the way.
Any ideas??? I mean it wasnt much oil but still idk what it could be
Wuiquen is offline   Reply With Quote
Old 04-07-2012, 09:04 PM   #2
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Put some newspaper down and see if oil is collecting!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 04-07-2012, 09:53 PM   #3
Wuiquen
Wuiquen's Avatar
Well i just moved the car today to a different spot and three hrs later there is another small drop on the floor. But now i am thinking it might be the catch can leaking because the drop is right under it and there is a small oil on the tube.. i have double checked the valve and it wont turn anymore so i know its closed.. maybe defective catch can???
Old 04-07-2012, 09:54 PM   #4
CaryE1
CaryE1's Avatar
Drives: Black 2011 2LT
I just took mine in today to the dealer for service and they said I have a small oil leak, too. I don't have any drips on the floor, though. They aren't sure exactly where it is, I am going to tale it in later this week for them to look further.
CaryE1 is offline   Reply With Quote
Old 04-07-2012, 10:11 PM   #5
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
These oil leaks sound similar to the one I had....it was a pinched O ring on the return line from the oil cooler....Dealer made short work of it and no more leak.
EMB135Driver is offline   Reply With Quote
Old 04-07-2012, 10:24 PM   #6
Wuiquen
Wuiquen's Avatar
how exactly did you point out where the leak was coming from?? my leak is somewhere on the driver's side of the engine. if you look at the engine standing in front of the car and on the driver's side, it looks like the oil is dripping right under the connecting arm to the wheel (idk what it called). like right under the black rubber thing that looks like is compressed.
Old 04-07-2012, 10:27 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
That would be oil cooler vicinity... lots of cars have had this problem.
Old 04-07-2012, 10:54 PM   #8
Wuiquen
Wuiquen's Avatar
well, maybe i am not along after all. I am hearing the same. lots of V6s with oil leaks. the weird thing is that my car has less than 2000 miles.. I guess I have to take it to the dealership. They will be able to find the leak right?? I just want to make sure it is not my catch can or any of my mods so the dealer doesnt charge me for service for it being my mods.
Old 04-09-2012, 10:15 PM   #9
rmoreno145
CHEVY ROCKS
rmoreno145's Avatar
Drives: 1990 454 SS 2016 Garnett Red 1LTRS
I had an oil leak too and it turned out to be the O ring on the oil filter lid. Check that first its an easy fix.
rmoreno145 is offline   Reply With Quote
Old 04-10-2012, 10:56 AM   #10
need4spd
need4spd's Avatar
Drives: 2012 2SS Black on Black
what is this with all the oil leaks on camaros.. my 2012 2ss had an oil leak at 500 miles.. brought to dealer, after few days still have a leak.. brought it in again today but they cant see where its coming from.. mine is leaking by the differential.. and I thought GM has learned quality.. I might be wrong
previous ride - 2010 CGM 2LT RS auto w/roof, eibach lowering springs, volante cai, mrt v2 axle back
current ride - 2012 Black on Black 2SS RS w/ sunroof, muffler delete with SLP exhaust tips, rotofab cai, gm strut brace, BMR 1.4 drop springs all four corners, Stainless Power 1 7/8 long tubes, Hex Vents, Jannetty Racing Tune, Helmholtz J pipe, MMR 228 Z28 replica wheels.
need4spd is offline   Reply With Quote
Old 04-10-2012, 11:01 AM   #11
ffrcobra_65
Drives: SuperCharged 2SS/RS IOM MN6
there have been so many complaints regarding oil leak after parking the car for long periods.
ffrcobra_65 is offline   Reply With Quote
This is why you get a catch can!!! BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 46 12-14-2011 08:52 AM
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 06:50 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
