04-24-2018, 04:57 PM | #1 |
ZL1 stone/splash guards
Has anyone had GM body coloured splash guards installed on a Gen 6 ZL1?
Debating whether fitment is an issue (besides cost) vs ZL1 Addons guards. Seems that Addons are satisfactory but I would prefer body colour and true fitment. Thoughts? |
04-24-2018, 05:03 PM | #2 |
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
No one makes them for the ZL1...I had a set of factory ones on my 16 SS. So far the ZL1addons have worked out well.
Still, I would buy factory look ones in a heartbeat! |
04-24-2018, 10:03 PM | #3 | |
Went with the RPI premium splash guards for the 2SS and these also seem to be on the smallish side, but so far they have done a pretty good job, and look good, too.
04-24-2018, 10:56 PM | #4 |
I like the ZL-1 add-ons.
04-25-2018, 06:33 AM | #5 |
Thanks for the input.
04-25-2018, 07:04 AM | #6 |
Drives: 2018 Silver ZL1 Join Date: May 2017
I just installed the front ZL1 add ons for the front and, so far, they seem to be a decent design and fit.
I am a little pissed about the rear set from ZL. I spent a bit of time installing the rears and no matter what I did or adjusted, they did sit flush all the way around the fender well. The problem is where the rear diffuser meets the bottom of the fender. I am particular about fit and looks and the rears drove me nuts. On top of it, the hardware they sent me for the install was all bright stainless Philips screws instead of the black stock torx. The stainless jumped out at me when installed and the entire rear set up looked like it was forced cheap. |
04-25-2018, 07:17 AM | #7 |
Drives: ZL1 Mosaic Black Join Date: May 2016
My positive experience with the ZL1-addons rock guards is:
1. they are sturdy and extend enough to protect the paint My negative experience with the ZL1-addons rock guards are: 1. the hole where the wheel liner pin goes into is not recessed 2. you may have to order new wheel liner pins because mine were too short 3. the 3M tape will show behind the rock guard due to it coming apart and the spacing Once you get the pins, the product performs as advertised; however, the fit and finish is unsatisfactory. Oh well...better bad looks than f'd up paint from rock chips!! |
04-25-2018, 08:02 AM | #8 | |
Do yourself a favor and take the rear tires off to install. But they do keep the burnt rubber off the pretty fender and they guys at Atco notice and like them. Me too.
"Democracy Dies in Darkness" |
04-25-2018, 08:48 AM | #9 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
I colored the exposed tape with a black sharpie. Blends right in. Not perfect in the back but I am the only one who sees that.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
04-25-2018, 09:15 AM | #10 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
2018 ZL1 1LE - Red Hot, Nav, PDR
04-25-2018, 11:43 AM | #11 |
Drives: '17 ZL1 Join Date: Jan 2018
Any pics?
04-25-2018, 11:54 AM | #12 |
Drives: '17 ZL1 A10 Vert Join Date: Mar 2017
I installed the ZL1 Addons front and rear. Overall I'm satisfied.
I have the same beefs as everyone else: 1) Screws for the rear are not black. Hard to see when the wheel is installed, but still no reason for these to be anything but black. 2) Mounting tape for the front is partially exposed/visible. Take a black sharpie to it before install and that pretty much solves the problem. 3) Factory wheel liner pin for the front wheel well does not work with the rock guards installed. Longer pin is mandatory. 4) Fitment of the rear is not perfect around the diffuser. But I knew that before I installed. All the above are minor issues to me. If I had to do it again, I would still get these. |
04-25-2018, 11:58 AM | #13 |
Can they be trimmed/modified to fit better?
04-25-2018, 06:40 PM | #14 |
The first picture shows the gap. It's because the diffuser sticks out a little and the rock guards were designed for a Camaro without the diffuser.
The second picture shows the mounting screws. They should be black, but to be honest, it's hard to see unless you get down on your knees and look for it. |
