09-02-2018, 05:18 PM | #1 |
Ponies are for girls
Anyone modify the intake manifold?
Hey guys,
Once I took off the heat shield, i noticed the composite intake manifold. Looking too industrial for me, i'd like to shave down the high spots and paint to look aluminum. My question is this, I'm not finding it done so "has anyone done this?" Did it work? I'm used to old school big blocks and small blocks, so the LFX engine is all new to me. |
09-02-2018, 06:00 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Someone filled in all of the spaces as opposed to grinding down the high spots - probably safer this way as those high spots are probably there for strength/rigidity. Maybe do a search on this forum to find the thread.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
09-02-2018, 06:47 PM | #3 |
Drives: 10 2ss/rs Join Date: Jul 2018
I think its in the list of diy's
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
09-04-2018, 08:24 PM | #4 |
Drives: 2015 Camaro Join Date: Aug 2018
I think the ribbed sections are for strength since it's made out of cheap plastic. I wouldn't grind on them if you don't have to.
09-08-2018, 11:03 PM | #5 |
Yeah, that’d be bad.
I guess I’ll focus on polishing the valve covers, and other aluminum pieces for beautification.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
09-09-2018, 11:46 AM | #6 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I had my intake ported after the headers were installed. Dynoed at 414/rwhp after that. Then a year later I installed the S/C and sold the intake.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
