10-24-2021, 10:13 AM | #1 |
Race Ramps? Which ones?
Hi, I am looking to get ramps, I started looking at ones around $50 and some how I am now up in the 4 to 5 hundred range.
https://www.raceramps.com/ramps/p/rr-xt-2/ Are these decent? Strong enough? I see they make a HD version of these for $100 more just not sure it is needed. Any other choices? I want to be able to change fluids easily and be able to time bushings if needed. https://www.raceramps.com/c/ramps/ Thanks
10-24-2021, 11:01 AM | #2 |
It don’t come easy.
I have the 67”, 2 piece ramps. They were around $350, when I bought them 2 years ago. Work great.
10-24-2021, 11:07 AM | #3 |
Drives: 2010 ss Join Date: Oct 2015
i have the two piece 67 as well,best ramps ever.had them for yrs
10-24-2021, 03:40 PM | #4 |
I am okay with spending the money, I just want to be sure I get the best ones.
10-24-2021, 07:04 PM | #5 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I would recommend using their angle of approach calculator.
https://www.raceramps.com/angleofapp...alculator.aspx
10-25-2021, 08:10 AM | #6 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
All I wanted was something to help me get the jack under the car. These are the ones I got to help with that since I'm lowered.
https://www.raceramps.com/ramps/p/rr-tj/ allows me to jack it up to the height I want and put jack stands for more secure support. |
10-30-2021, 05:46 AM | #7 |
I have the 67's Coming, hopefully I like them.
10-30-2021, 07:39 AM | #8 |
It don’t come easy.
I think you’ll be satisfied. Did you go with one piece or two?
10-30-2021, 08:46 PM | #9 |
2 piece
10-31-2021, 01:37 PM | #10 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
I had home made ramps until I got lift pads and a low profile jack. Don't have to worry about storing the ramps now.
10-31-2021, 07:22 PM | #11 |
I have a couple Low Profile Jacks and I just added the ZL1 Pads last week as well.
11-05-2021, 04:50 PM | #12 |
The ramps came yesterday, They appear well made I don't have my front splitter on yet and I do think its going to hit, It does push up on the air dam underneath the front bumper, I have a 12x12x1 board cut for each front wheel that i'll have to drive up on. I have not put the car up yet but I will Tomorrow. They are made of a really rough textured foam, Hopefully they last a long time especially for the price.
