07-24-2021, 12:27 PM | #1 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
BTR .660" LIFT PLATINUM SPRING KIT
BTR .660" LIFT PLATINUM SPRING KIT WITH TITANIUM RETAINERS FOR GEN V LT4 - SK008
New Kit, never used. Price $270 including shipping to the lower 48 states DESCRIPTION .660" Lift Dual Spring Kit for Gen V LT4 engines using stock rocker arms.* Includes dual polished springs, matching LT4 specific titanium retainers, LT4 specific locators for stock guides, locks and seals.* * Spring specs are 155 lbs @ 1.780", 380 lbs @ 1.180", 400 lbs @ 1.130, coild bind @ 1.070"* * This is a drop in spring kit for Gen V LT4 engines,*WILL NOT FIT OTHER GEN V ENGINES, SEE SK007 Complete List of Kit Componets SP001-1.660" Lift BTR Platinum Dual Valve Spring16 SR006-1SINGLE LS9 TITANIUM RETAINER8 SR008-1TITANIUM RETAINERS FOR GEN V LT1 HEADS8SL520045-1BTR Spring Locator; .520" ID, .045" Thick8 SL520060-1BTR Spring Locator; .520" ID, .060" Thick8 VS LS KITBTR LS Valve Seal Kit; Set of 8 Black Intake Seals and 8 Brown Exhaust Seals VL7°8MM-32LS VALVE LOCKS 7 DEGREE BEAD LOCK SET OF 32 1SS015-1BTR .015" Shim for Stock Guides8
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-05-2021, 01:44 PM | #2 |
SOLD!
2018 Camaro ZL1 A10
