Old 12-01-2020, 12:35 PM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Question Weapon X HPFP Spring, Lash cap question
Just ordered my new Cam with a 306" lift fuel pump lobe, I belive that converts to 38%.
Is anyone running the weapon-x high pressure fuel pump spring? Should I order one? https://weaponxmotorsports.com/colle...=6123267129371
Also do I need a lash cap with my new cam and the stock LT4 pump?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 12-05-2020, 04:24 PM   #2
swisstyphoon
Bringing this back up.
Anyone using the weapon-x spring?
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 12-07-2020, 11:47 AM   #3
scooter k
Drives: ex-wife's car
I'm using that spring with no lash cap. From trying to measure it the lash cap was too much. I've had no issues so far with mine.
scooter k is offline   Reply With Quote
Old 12-07-2020, 12:48 PM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Have been running factory spring since 2018 with 38% fuel lobe cam, no issues observed
LiqTenExp is offline   Reply With Quote
Old 12-08-2020, 12:39 PM   #5
swisstyphoon
Thanks for the feedback guys
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 12-08-2020, 02:00 PM   #6
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
My brother has a nasty ‘16 Z06 and I have my Whipple’d SS, we’re both running custom CamMotion cams with the bigger fuel lobes and LT4 HPFP. He has the Weapon X HPFP spring and I do not. We have not seen any evidence to date that it made any difference, for what that’s worth.
Old 12-08-2020, 02:16 PM   #7
swisstyphoon
Cool, thanks.
You helped with my decision.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
