08-13-2020, 01:07 PM | #1 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Voltage booster vs. DSX Aux fuel kit
lets hear pros and cons.
I don't like to drill the tank, and heard the Aux kit won't work for road corse racing, because of the fuel pick up location... Wish there would be an option that uses the stock pump basket...
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-13-2020, 01:08 PM | #2 |
Drives: Turbo 6.2 Join Date: Feb 2019
Dsx will support more power but you have to drill into your tank.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
08-15-2020, 04:33 AM | #3 |
Drives: Awsome Join Date: Dec 2018
I think Fore innovations have bigger pumps in tank
08-15-2020, 06:33 AM | #4 |
No bucket with the Fore setup. Probably fine for street and drag racing, but will be a problem if you track the car.
08-15-2020, 08:00 AM | #5 |
I made somewhere around 875 rwhp with Voltage booster and just an Lt4 pump in tank on 18 lbs of boost with race fuel. Wish I'd done the Dsx lowside, never came close to the full potential of the forged motor and 2650 Maggie. Obviously I also had the Lt4 HPFP and injectors.
08-15-2020, 07:50 PM | #6 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
Voltage boosters are okay but they aren't going to deliver much more fuel. If you are just starting to run out of fuel they can help out but the next round of mods will usually knock them out.
08-15-2020, 09:39 PM | #7 |
Drives: '17 ZL1 Join Date: Jul 2016
DSX kit is garbage. Don't bother with that.
If anyone is creating a museum of poorly engineered automotive accessories and would like a Camaro DSX Tuning Supplemental Fuel Pump Kit for a featured exhibit, I have one with just a few hours on it I'll sell for half price.
08-15-2020, 11:09 PM | #8 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I imagine the booster with a cam will supply over 800whp without an issue. I can’t imagine you need more than that.
08-16-2020, 02:50 AM | #9 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
1 or 2 of these with Ti 285s in a Fore might work.
https://www.holley.com/products/fuel...s/parts/16-111 |
08-16-2020, 09:16 AM | #10 |
The Fore system has issues on the road course too. There is a thread on here about it somewhere.
I haven't tried anything above 17.5v with the JMS booster, but I'm at the very limit at 700 RWHP on 93. The same scenario with fuel sloshing to the lefthand tank also reduces the fuel supply capacity of the stock pump. At 17.3V and 700RWHP I have dropped fuel pressure after a hard right turn and a long straight. I have never had any pressure loss at 17.5v. I know the JMS booster can go higher, but I imagine going much higher than 17.5v could cause issue with the FPCM and/or pump.
08-16-2020, 10:12 AM | #11 |
This sounds interesting:
DIY DW400 pump upgrade. Just wonder if the fuel pump module can handle the extra load over time.. https://www.camaro6.com/forums/showthread.php?t=567023
2018 Camaro ZL1 A10
08-16-2020, 11:38 AM | #12 | |
08-16-2020, 11:47 AM | #13 |
The upgraded pump in the OEM form with the bucket intact seems like a good solution. I just wish a reputable company made a nice drop-in upgrade like this. The solutions currently in the aftermarket all seem to be geared toward drag racing while ignoring challenges that come about for those of us using our steering wheel.
08-16-2020, 11:49 AM | #14 |
Cool, let us know how it turned out.
2018 Camaro ZL1 A10
