09-22-2019, 11:05 AM | #1 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Colder plugs, bad idle
My car is tuned, lower pulley and they also put Brisk RR14s plugs in it. (gapped between 0.027 and 0.031) Since that the car has a bad idle every cold start. Missing and surging. The colder, the worse.
Here the link to the video took a few weeks ago, check the 29sec, and the 42sec mark:* I changed the plugs today and put the stock ones back in (gapped to factory specs 0.040), to find out if maybe the colder plugs caused this. And sure enough my idle is back to normal. My question now, am I risking burning a hole in my pistons running the stock plugs, or should I better go back to the colder plugs, and suffer a little driveability when cold.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 09-22-2019 at 03:18 PM. |
09-22-2019, 04:30 PM | #2 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Might want to talk with your tuner about that. I changed my plugs to the NGKs and have had no problems after a good tune. My first tune was not so good. Car would idle low and sound as if it was going to shut down. Then at times the car would buck a bit at certain RPMs. Once I took it to another tuner, it all got corrected and the car is outstanding.
09-22-2019, 08:46 PM | #3 |
put a one range colder NGK in it and everything will be perfect
09-22-2019, 08:52 PM | #4 |
This. Did that to my SS after installing the Whipple. No problems at all.
09-23-2019, 11:02 AM | #5 |
Drives: 2017 ZL1 Join Date: Mar 2014
IMHO, NGK >> Brisk
09-24-2019, 06:52 PM | #6 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
That sounds like fueling isnt correct. After it warms up some it goes into closed loop and 02's will correct fueling. If VE table isnt dailed it it will act crazy.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
09-24-2019, 07:14 PM | #7 |
Drives: 2019 2SS Join Date: Mar 2019
I found the same problem with various cars over the years.
09-28-2019, 12:21 PM | #8 |
Thanks for the input guys, switching to NGKs now.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
09-28-2019, 01:04 PM | #9 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
We run NGK TR7s on the LT4s with a lot of success
