AWE Tuning
Old 06-26-2017, 04:35 PM   #1
SSTG
Drives: 2014 Z51 Corvette
Headliner replacement?!
I did a search on the forum and found limited information.
When is it noticeable that the headliner needs replacement? Is it when you first buy the car or after it is driven for a while?
Also did I read correctly that the windshield has to be replaced if a headliner is indeed needed?
I'm looking into buying a new ZL1 and if that's the case I really don't want to mess with it at this point. Hopefully GM will get their stuff together with later build quality.
SSTG is offline   Reply With Quote
Old 06-26-2017, 05:07 PM   #2
JDono
JDono's Avatar
Drives: 2024 ZL1 M6 Vert - Riptide Blue
When purchasing my 17 a week ago or so I discovered that 1 out of 5 headliners fit as intended based on the vehicles I looked at. The issue was at the front at the corners. There's a section of the headliner at these places which is thicker than in the middle. At the front the headliner is supposed to curve up towards the roof at approx 90 degrees or so. Only one headliner had this curvature and was tight where it met the windshield . The others all continued straight, displaying a frayed edge. They all also varied in looseness. One of the headliners had enough gap for me to fit my hand between it and the roof.
I talked with the service manager about it and he said that there's nothing holding the headliner in the front and the fit was based on the form of the headliner itself and how it fits into the "A" posts. So basically they fit how they fit from the factory.
He highly advised me to let it be as mine was tight to the roof but just lacked the correct curvature. He printed out the instructions for replacement which included removal of both windshields and in my case a lot of messing with the sunroof. I chose to just let it be as no one else would probably notice it.
JDono is offline   Reply With Quote
Old 06-26-2017, 05:22 PM   #3
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
I may be wrong but I thought the front corners were also curved to accommodate the side airbag. Mine is visible but not overtly obvious, still after a year I do want to find something to either cover it or hold it up.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 06-26-2017, 06:24 PM   #4
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Oh crap!
I never realized there were so much problems with the headliner. I am having my car in for service and I am having them look at mine for a rattle (can hear it on any non-smooth / new pavement). Hopefully they can just get whatever little clip is rattling to shut up without the bigger maintenance project.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 06-27-2017, 08:54 AM   #5
SSTG
Thank you for the info.
Sad that a $70,000 dollar car has these issues.
Old 06-27-2017, 12:53 PM   #6
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Drives: 2017 HBM 2SS Convertible A8
Sure glad I have a convertible no issues with the headliner
#TeamBeckyD
**FIFTY HBM 2SS VERT**
01pewterz28 is offline   Reply With Quote
Old 06-27-2017, 03:54 PM   #7
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
my headliner is a little loose in the rear passenger side by the rear window glass.
I just purchased a couple new retaining clips and plan on popping the old one out over there and throwing in the new one.
I assume they're the cheapy single use type that destroy themselves when you remove them and bumps etc just caused one or two rows of the plastic to bend on the original clip leading to this looseness. No big deal.
cellsafemode is offline   Reply With Quote
Old 06-27-2017, 05:07 PM   #8
redcoats1976
thats weird,the headliner on my overweight,low quality 5th gen fits just fine.
Old 06-27-2017, 05:51 PM   #9
JDono
JDono's Avatar
No issue with the headliner on my 2011 or my 2014.
Old 06-27-2017, 05:56 PM   #10
Smashn808
Smashn808's Avatar
Drives: SS
There was no clip under the front of my headliner. It was rattling/ chirping like crazy until they fixed it.
2017 HBM 1SS 1LE w/PDR
Past:
2009 Cadillac CTS-V, 6-speed manual
2008 Corvette Jet Steam Blue, manual
2005 Cadillac CTS-V, Stealth Gray
2003 Corvette Z06, Black
Smashn808 is offline   Reply With Quote
Old 06-27-2017, 06:24 PM   #11
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
Have you ever seen a lose dress on a Fat woman? There is your answer..
When their lean and low weight you always have that chance the dress may fit a little lose
By the way no issue with mine so far
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 06-27-2017, 07:31 PM   #12
redcoats1976
LOL...
Old 06-27-2017, 08:19 PM   #13
SSTG
Does anyone have pics so I know exactly what I'm looking for when I check out the car?
Old 06-27-2017, 08:41 PM   #14
JDono
JDono's Avatar
Top left/right corners. Mine don't have much gap but as you can see the edge is straight exposing the frayed edge as opposed to tucked back up to the roof.
