Old 04-17-2014, 10:42 PM   #1
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
ZL1 bumper on LS with DIY harness + switches
I did this install back in November but haven't had a chance to post about it till now. I would like to thank all the members who contributed to this forum because it was great help. This actually was multiple installs in one: I got the ZL1 bumper, DIY harness, Curb Alert, and camaro2lt's idea of ZL1 bumper cold air intake ducting.
For the bumper, I contacted MaureenM@RodgersChevrolet, and she had a pre-painted ZL1 bumper. I took a risk and got lucky because the paint match was perfect. Specifically, I got:
#22831868 Fascia
#22895338 R Bezel
#22895339 L Bezel*
#22894223 Lower Grill*
#20952857 Support*
#20952853 Absorber
#20957334 DRL Retainer (you need 2)*
For the nuts and bolts, I refused to pay GM's prices and got replica parts with the same dimensions that worked just as well. For the bolts part #11570637 , I bought "Phillips Pan Head Sems Tap Screw M4.2-1.41 X 20mm." For the nuts part # 11610157, I bought "Nut With Silicone Pad." The only thing I got from GM were the plastic rivets (# 92231490) and two clips*(#11562364) because they weren't expensive.
For the upper fog lights, I got 2007-2012 Chevy Avalanche/Tahoe fog lights (same as Camaro's) off ebay, which house Putco Pure Jet Yellow 3000k 9009/H16 bulbs. I had to modify ZL1 DRL retainers to hold the lights by cutting off the top part of my LS retainer, where the adjust arm would sit, and using some plastic weld epoxy to add it to the ZL1 retainer.
I got the lower fog lights off amazon, and used 6000k H11 7w LED lights (match my 6000k EE halos).
Making the harness was the most challenging part but was fun because it forced me to relearn the basics of electricity physics and circuit design. Also, because I have an LS, I had no pre-wiring for fog lights and I wanted to be able to control each set through in-dash toggle switches. The most important things are to figure out the amperage, correct wire gauge, fuse sizes, and select the right power sources. It also involves a lot of splicing and connecting (through crimps and liquid electrical tape), and you need the right wire pigtails for the bulbs, but I integrated everything into one harness by using a wire loom.
(wires before loom)
The Curb Alert system, LED fog lights and LED indicators on the toggle switches, which all draw little power, are all connected by an dd-a-circuit plugged into slot F18 in the driver side fuse box. The halogen upper fog lights are rated at about 37 watts so I connected those to the battery through a $10 ebay relay, with the trigger coming from the F18 fuse going through one of the toggle switches. By the way, the F18 fuse is an ignition fuse, so the power goes out when the key is removed, which will protect the battery if you leave the switches on the "on" position.
Lastly, since Virginia requires front plates and I didn't want to ruin the fascia, I didn't like the off-the-shelf solutions, I decided to cut off the bottom on the plate and installed it in the lower grill. I cushioned the back of the plate and held it with long bolts and padded washers.
It's been six months and the harness has held up through winter with no problems.
Inuyashas_Brother is offline   Reply With Quote
Old 04-17-2014, 11:41 PM   #2
FilibustaRhymes
FilibustaRhymes's Avatar
Drives: SS
Great work! Thanks for sharing the part numbers and stuff - something to keep in mind.
FilibustaRhymes is offline   Reply With Quote
Old 04-18-2014, 01:54 AM   #3
sdmaro
Drives: 2011 LS Camaro
Friggin awesome! Still waiting to find a cheaper set of RS lights since I will spend a ton in harnesses.
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline   Reply With Quote
Old 04-18-2014, 08:15 AM   #4
mattuz
mattuz's Avatar
Drives: 2011 victory red camaro
Looked great, nice job!
mattuz is offline   Reply With Quote
Old 04-18-2014, 09:00 AM   #5
jgray1978
jgray1978's Avatar
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
So do you run all six lights at night? I believe that it's illegal in most if not all states to have more than 4 but I run all six myself. Never hassled.
jgray1978 is offline   Reply With Quote
Old 04-18-2014, 05:36 PM   #6
Inuyashas_Brother
Thank you all. Just to note, my headlights and halos are Eagle Eyes off ebay, and they have been working great since 2010.
One other thing I forgot to mention is that you might want to invest in getting a Dremel. I bought one just for this install and used it to 1) modify the DRL retainers, 2) cut the two pieces circlered below, 3) drill the the extra hole needed to bolt the wheel well onto ZL1 bumper, 4) drill the holes for the switches, and 5) trim the license plate.
I don't know what the rules are in VA, but I usually don't. That's the beauty of independent switches - I can pick and choose based on mood or need.
Old 04-18-2014, 08:09 PM   #7
sdmaro
I forgot to cut those and mine won't sit flush.. I am too lazy to redo it until I get my heritage grill haha.
Old 04-19-2014, 03:47 PM   #8
JCO2185
RIDING ON AIR
JCO2185's Avatar
Drives: 2010 2LT/RS Summit White
great write up
--John--2010 Camaro 2LT/RS, Summit White
Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels
JCO2185 is offline   Reply With Quote
Old 07-13-2014, 09:47 AM   #9
FloMaro
FloMaro's Avatar
Drives: 2013 V6 Camaro
Wow Bro This Is Exactly what I needed To See! Tudah(Thank You)
FloMaro is offline   Reply With Quote
Old 07-13-2014, 07:19 PM   #10
Optimus
Drives: Former 2010 and 2013 Camaro owner
Freaking Sweet! I just picked up a brand new 2013 2SS 1LE and love it. While a ZL1 is way more than I need at this point in time, that bumper is sick. Tons of possible mods and what you did was one of the first ones on my to do list. Nice Work.
Optimus is offline   Reply With Quote
Old 07-21-2014, 10:57 AM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
#22831868 Fascia
#22895338 R Bezel
#22895339 L Bezel*
#20952857 Support*
#20952853 Absorber
(wires before loom)
Looks awesome.. so if you have fog lights but not a Zl1 bumper it should be easier? No wire nightmare lol?
EDFHOBBIES is offline   Reply With Quote
Old 12-31-2014, 01:01 PM   #12
Inuyashas_Brother
Sorry - just saw your question. Yes, though you would need splice in the wires for the lower fog lights. In case there are LEDs and draw very little power, but I have seen others install HIDs with a relay. It also depends on whether you want to be able to control them independently from the regular fog/DRL lights, which why I installed a separate circuit and switch.
Old 11-17-2017, 09:56 PM   #13
killercamaro23
Drives: 2012 camaro 2LS
Old post but looking for a little help. When adding the lower support on the zl1 bumper and lower grill, what did you use to plug them holes and make everything tight? i used factory clips and didn't work :/
3.91 Gears, Ported Intake Manifold, Intake Manifold Spacer, 80mm Throttle Body, Cold Air Inductions Intake, Trifecta Tune, Solo HighFlow Cats, BBK 2.5"Xpipes, ZL1 Mufflers, Forgestar F14 wheels
250lb weight reduction !!!
killercamaro23 is offline   Reply With Quote
Old 12-14-2017, 07:53 PM   #14
orange devil
Drives: 2019 SS 2019 mustang GT
I just got my ZL1 front bumper cover when I get a chance to install. it and if I run into the same problems you did I'll let you know what I did to fix it .most likely I'm going to use Hardware instead of plastic fasteners .I'm going to bolts nuts and washers
orange devil is offline   Reply With Quote
fog lights, harness, zl1 bumper
