07-26-2017, 09:19 AM | #1 |
[COTW 1/6/14]
Drives: 2017 1LE Join Date: Mar 2012
Car Shakes Under Acceleration
wasn't quite sure where to post this.. so I thought I might as well post it here..my car has recently hit around 4500 and ive noticed that when under mid to heavy acceleration the whole car shakes... well its more like the front end.. at first I thought I was a bad alignment. but I just had the car realigned at 1500. also when it comes to cruising speed its smooth.. this only happens when I accelerated.... was wondering if anyone has any suggestions on what it could be.
07-26-2017, 09:51 AM | #2 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
My car has always done the same. It's just vibration it seems. Can feel it under 60-70 throttle scenarios
07-26-2017, 09:55 AM | #3 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Where do you feel the shaking the most? In the steering wheel? In the floor pan where your feet rest? In the seat? Is it more of a buzzing/vibration that you feel? I'd be very surprised if it was coming from the front suspension under acceleration if there's nothing in under cruising or braking.
2017 SS 1LE.
07-26-2017, 09:57 AM | #4 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Read this whole thread. I'm willing to bet you are experiencing the same thing. Nothing bad just an odd Harmonic vibration that the car has.
http://www.camaro6.com/forums/showth...gine+vibration
MJK3888 Instagram Link
07-26-2017, 10:12 AM | #5 | |||
[COTW 1/6/14]
07-26-2017, 10:49 AM | #6 |
"M1SS1LE"
If you are specifically noting it through the wheel and have already done an alignment then get the tires re balanced.
07-26-2017, 11:31 AM | #7 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Yeah, I don't think you are talking about the normal slight harmonic drivetrain vibration these cars can get. As mentioned in the thread mjk3888 posted, as that is pretty slight, occurs only in a certain rpm range, and seems to only be in 3rd and 4th gears too. It really won't be noticed under normal driving conditions at all.
If you are saying you feel it in every gear when you accelerate, and in the steering wheel, you have something else going on for sure...could be so many things, tire balance issue, exhaust hitting some place, loose heat shield, etc, etc... |
07-26-2017, 01:32 PM | #8 | ||
[COTW 1/6/14]
07-26-2017, 01:46 PM | #9 | |
"M1SS1LE"
03-05-2021, 07:55 AM | #10 |
Drives: 2017 camaro 2.0 lt Join Date: Oct 2020
My car is shaking, it’s shakes when I turn it on and when I’m on the throttle, I see white smoke coming out the back when I press the gas. The smell is kind of burnt type of smell, I’m not sure what it is.
03-05-2021, 08:01 AM | #11 | |
'20 ZL1 1LE A10,
