05-17-2019, 01:10 AM | #1 |
Drives: 2010 Camaro 2ss Join Date: Mar 2019
Lifter noice or header exhaust leak ? 2010 SS
Trying to figure out the best way to go about this . 2010 camarosswith long tube headers not sure which brand , bought it used. Has borla x pipe /attack , high flow cats . So it's hard to tell if this ticking noice is a bad, sticky worn lifter or just a simple header gasket leak ? Will post video if I get any feedback . But Its seems louder at a cold start . After driving to work out in park , and revd it up in park and the ticking noise was hardly noticable or was that because I was in park and not underload ?
05-17-2019, 06:28 AM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Manual or auto? If auto and only at random startup, it's possibly the afm/dod lifters. Search for TSB for faulty lifters. They're not catostrophic but sound that way.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
05-17-2019, 06:41 AM | #3 |
376 cubic inches of fun
The collapsed lifter noise lasts only a second or two. It is caused by the AFM lifters, which are activated by oil pressure, to lose pressure when the engine is off for a few hours or more. The noise stops as soon as the lifters regain pressure.
Permanently damaged lifters are a different problem. Hopefully someone will weigh in on how to locate a gasket leak in a non-invasive way. |
05-17-2019, 12:58 PM | #4 |
If it's a leaky gasket you can check using a flexible piece of hose (heater hose). Place one end to your ear and the other end where the primary tube is welded to the header flange. If you find one louder than the others you found your leak. You can do the same for the collector gaskets and where your piping slides together.
Lusinda 2010 2SS/RS |
05-17-2019, 11:15 PM | #5 |
Drives: Never just fly under the radar Join Date: Jul 2015
Old Skool |
05-18-2019, 08:41 AM | #6 |
old school chevy rodder
MR.ONE POST...……..most likely its the normal tick of the typewriter sound noted from the roller lifters of a LS engine which is louder when you modify the exhaust with headers...…… no sound clip no advice.
05-18-2019, 08:42 AM | #7 | |
Evil Genius of Chevrolet
05-18-2019, 09:45 AM | #8 | |
I use Delco PF48E filters. |
05-18-2019, 10:16 AM | #9 | |
Space Shuttle Aficionado
If it sounds like a sowing machine, it's normal.
05-18-2019, 01:26 PM | #10 |
WTF does that have to do with anything?
05-18-2019, 06:33 PM | #11 |
05-18-2019, 09:48 PM | #12 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
It's no doubt the lifters if it's an L99 auto. My early '10 SS L99 lifters have never
made a sound, never even once. I attribute that to frequent oil changes, 15 so far with only 58,000 miles. Change your oil and change it often imo.
