Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Mechanical Maintenance - break-in, fluids, parts, servicing, etc.
Old 07-31-2014, 11:09 AM   #1
Gabbott
Gabbott's Avatar
Drives: 2014 Crystal Red C7 Convertible *
C7 Battery Maintainer
Anyone have experience yet with this new battery maintainer from GM, that you can order as an option with your C7?
I have a convertible. After examining the procedure to hook this device up to the power port in my trunk; I observe that the two trunk lights stay on unless the trunk is completely closed.
And, you can't completely close the trunk, as long as the battery maintainer cord is connected to a home power source.
I didn't see anything in the instruction booklet that came with it about having to leave the trunk open the whole time that the maintainer is connected..........with the two trunk lights on?
I waited a good while to see if the two lights eventually go off, but they seem to stay on as long as the trunk is open.
I'm hoping that some of you folks can provide input here.
Gabbott is offline   Reply With Quote
Old 07-31-2014, 11:37 AM   #2
route66
Drives: 66 coupe 78 pace car 2014 coupe
I would assume the trunk lights in the convertible work like the coupe lights and they do shut off after a fairly long period of time, I do not really know how long it takes. The first time I used my maintainer I was concerned about this also. I hooked up the maintainer went in the house checked in about 1/2 hour and they had turned off.
route66 is offline   Reply With Quote
Old 07-31-2014, 11:39 AM   #3
Gabbott
Gabbott's Avatar
Disregard the above post.
I re-read a paragraph in the owner's manual, and learned that all of the vehicle's lights are designed to turn off, after 10 minutes, if the vehicle is not running.
Sure enough, after ten minutes the two trunk lights went out. I just didn't wait long enough, prior to submitting the above post.
All is well, and my maintenance charger is working
Old 07-31-2014, 08:39 PM   #4
Dada
Drives: Z51 White on Black
How does it work, Im getting one, just plug in the battery port for how long?
Dada is offline   Reply With Quote
Old 07-31-2014, 09:00 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
A c7 will start after a month worth of sitting. Posts all over the boards verifying this. If you store for longer, get a maintainer, anything shorter and it's not needed.
Old 08-06-2014, 10:17 AM   #6
Dada
I read the instructions, its quite simple, just plug in and wait for it to light up as full. Will it harm the battery if we are away on a trip and I leave it plugged in for a week?
Old 08-06-2014, 07:30 PM   #7
Stingray
just can't get enough
Stingray's Avatar
It won't harm the batt whether plugged in 1 day or 1 week or 1 month or 1 year etc... I have my 'vert plugged in with trunk closed. No kinks on the cord neither... but I am careful and do have the cord flat (not tangled or spiraled) and cord closed on the corner of the trunk lid. No issues.
Old 08-23-2014, 11:58 AM   #8
JDMAC
Drives: 2015 Laguna Blue C7
I have been using a Deltran Battery tender Plus on my 1999 C5 for a couple of years. The unit has worked flawlessly since I purchased it. When I purchased unit cost was around $50.00. Not sure what they cost now but would be willing to bet it is under $100.00
JDMAC is offline   Reply With Quote
Old 09-30-2014, 08:11 AM   #9
SR-71
SR-71's Avatar
Drives: 2015 Z51 Coupe 2LT Shark/red
What is the max charging current the C7 Battery Maintainer puts out? It looks pretty small. The Battery Tender is 1.25amps.
SR-71 is offline   Reply With Quote
Old 10-14-2014, 08:33 PM   #10
Dada
also I drive my vette once a week and I only have 500 miles on it, when should I use the charger, when I know I won't be driving it for a few weeks or too new to worry about it?
Old 10-15-2014, 08:55 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
3 weeks or more sitting, hook it up.....
Old 03-16-2015, 07:28 AM   #12
Dada
Will this work on other vehicles?
Old 03-16-2015, 09:49 AM   #13
purpleRac3r
purpleRac3r's Avatar
Yes, however it may not work through the other car's power port, depends on how the electrical system is designed. You can get the C-Tek alligator clips from the manufacturer, and many local speed/street rod shops sells the accessories. I've been using one on my '74 Stingray for several years now. The only difference between your maintainer & mine is you have the new Stingray logo printed on the case.
purpleRac3r is offline   Reply With Quote
Old 06-06-2019, 03:35 AM   #14
rdanzel
Drives: 2010
I bought a ctek and it works great. I use it on my other cars also.
rdanzel is offline   Reply With Quote
