Old 07-20-2020, 01:43 PM   #1
ZL1_David
Drives: 2013 ZL1 Camaro
Fuel Pump or Tuner Issues
I have a 2013 ZL1, got the aux pump and flex fuel sensor kit from SMG. Installed the pump and flex fuel sensor no issues. Took it to my tuner that got the license to tune the fscm but every single time we hit ~4800-5k rpms the computer cuts fuel causing my AFR to lean out. It'll go from 65psi straight down to 35psi on the pump. My tuner says its the pump, when i contacted SMG they said its the tuner. The reason SMG says its the tuner is because its consistent at the rpms and the graph shows an immediate fuel cut off, not a slow pump fail of it not being able to keep up. So im stuck between a rock and a hard place, either its the pump or the tuner. I hate to say tuner because I have a long standing relationship of him tuning my last 4 cars with ZERO issues. Any help, suggestions, or guidance would be appreciated.
I know some people have mixed feelings about SMG, this is my first possible issue with them IF it is the pump.
ZL1_David is offline   Reply With Quote
Old 07-20-2020, 04:08 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Has your tuner ever tuned an aux pump in a 5th gen? Things in the tune need to be adjusted to prevent the fscm from trying to drop pressure once the aux kicks in, and also allow the higher pressure you desire. Need to look at the max desired pressure, the flow vs pressure tables, and the min duty cycle at a minimum.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 07-20-2020, 08:50 PM   #3
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
When DSX did my tune he also made chances to the FPCM
Crash76 is offline   Reply With Quote
Old 07-21-2020, 08:30 AM   #4
Full_Spectrum
Drives: 2013 ZL1
It is absolutely the tuner.
Full_Spectrum is offline   Reply With Quote
Old 07-22-2020, 08:07 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
Yeah it's in the tune. These 5gen fpcm set ups are a pain and don't make a ton of sense until you've done a couple. These aux pumps don't exactly work with the fpcm very well until they are tuned for it. Have your tuner contact SMG and they'll get it figured out.
Old 07-22-2020, 04:26 PM   #6
ZL1_David
have contacted them, they offered no tuning support
Old 07-24-2020, 11:08 PM   #7
Juiced1
Seems to be a common theme with these aux pump guys. Tell your tuner he needs to tune the fpcm to make it work.
Old 07-26-2020, 12:34 PM   #8
d454brisson
Drives: 2014 ZL1
do you have the hpt files? Can compare to mine with a dsx, i see drop through the range but its just usage not a cut.
d454brisson is offline   Reply With Quote
